Closed Thread
Old 09-30-2003, 11:25 AM   #1096
rayhuang's Avatar
I'll have enough for you...OH wait-I have yet to beat you-OH well-wait till this weekend!!! :devil:
Ray
rayhuang is offline
Old 09-30-2003, 11:27 AM   #1097
CypressMidWest's Avatar
It's all in the wheel Ray, it's all in the wheel!
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline
Old 09-30-2003, 02:09 PM   #1098
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Default Re: Demon 2
Originally posted by Doug D
Does anyone have any comments about the Demon 2? I run foamies on carpet and am having a hard time deciding on the Demon1 or 2?
Also, are there different versions of the Demon1? 3mm or 2.5mm chassis? With different top braces????
Axiom5B - Any input on this? Also, what car are you running?
Thanks for the help!!!!
Doug,
I would personally recommend the Demon 1 for carpet with foam tires. I am running a Demon 1 with 3 mm chassis and 3 mm top plate. It is working VERY well right now, easy to drive very fast. I am planning on trying the 2.5 mm chassis with 3 mm topdeck just to see how it feels with lower roll centers. FYI for anyone buying a Demon/Demon2 there is no noticeable difference in stiffness on the track between 2.5 mm chassis and 3 mm chassis. The difference you will feel is in the roll center of the car.
Ray, be sure to send me a setup for the champs man! Warpspeed is gonna go fast for sure!
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline
Old 09-30-2003, 02:30 PM   #1099
Doug D's Avatar
Trader Rating: 54 (100%+)
Axiom - Thanks for your input. I spoke w/ Victor today and he said after running the D2 it was initially very twitchy. He also said it was a lap faster then his D1 as well.
My only concern is potential twitchiness on the carpet, especially at national level competition where the traction is sick, i.e., birds, Cleveland Champs, etc. I guess only time will tell how the D2 will perform.
Ray - Anyone in your area running the D2? How do you like the D1? What are the major differences you noticed from the tube chassis? I know your racing venue has some of the nations fastest carpet racers......
Doug D is offline
Old 09-30-2003, 02:31 PM   #1100
Doug D's Avatar
Ray - What chassis are you running? 2.5 or 3 mm? Thanks!
Doug D is offline
Old 09-30-2003, 02:55 PM   #1101
speedxl's Avatar
doug i have run the car on the layout and the actual carpet for the snow birds at minnreg and with a high traction level and with full diffs the car was dialed compared to my d-1 and my ft car both had oneways and his car was 2tenths faster then my car. the car was stabile never felt twicthy or felt like traction rolling.
it did turn on a dime due to the wheel base, comparing it to my d-1 is nite and day difference any body want to by one of the origional prototypes
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline
Old 09-30-2003, 03:55 PM   #1102
speedxl, was this on rubber or foam tires?
As I and Ray have said, the Demon 2 will be dialed for anything with rubber tires. For foam on carpet i'd still say the D1 will perform better at large races or really high-traction tracks. Trust me, the car has no problems in the steering dept!
USVTA Member #211
Old 09-30-2003, 04:05 PM   #1103
Fred Hubbard's Avatar
Default Re: Re: what's needed
Originally posted by lem2
My demon is on its way! I got the following already:
NTC3 swing rack part number 2229
NTC3 swing rack hardware part number 2228
just use the bearing on your stock TC3 steering!
while waiting, i am also painting a new body!!!
get some sand papers also to finish up or prep the chassis
its also a good idea to buy chassis protector. I use 3M bath tub tape!!
Oeace and happy racing!!
Lem
I forget the AE part number, but you should replace the bushings included in the swing rack hardware kit for bearings.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline
Old 09-30-2003, 04:09 PM   #1104
speedxl's Avatar
this was with rubber tires axiom but i sure youre thinking the d-1 being longer will be easier not the case rememder shim the rear hub to the rear and make it a little longer pluss we all know theres enough adjustment to take traction out of the d-2 if its to much. i actually think the car with the shorter wheel base will be a better choice i have tried the tc3 with long and short wheel bases and can tell you wether its on foams or not i always felt the car to be dialed with the shorter wheel base maybe for me because i am an old school 12 scaler and like a somewhat nervous car because the faster you go the less twicthy its becomes!
speedxl is offline
Old 09-30-2003, 04:50 PM   #1105
Well, I'm just saying at the extremely high traction races many of us go to it can often be difficult to get rid of the twitch and compensate for the increasing traction. One of the ways we do this is to lengthen wheelbase. Having a longer wheelbase to start from will allow us to go faster from the beginning.
USVTA Member #211
Old 09-30-2003, 07:19 PM   #1106
rayhuang's Avatar
I am buying the Demon2 after all and hope to have it installed and ready to race on October 12, 19, etc.... It will only take two race weekends to know which one to use against the guys I race against every week.
I will have a real good idea for comparison for everyone then. I tend to sacrifice the ultimate set-up in an effort to make my testing legit-so I will be putting the exact same set-up that my D1 has on it after this Sunday's race. Then tweak it one change at a time as usual for me.
If I could get paid to test RC cars (or Race cars, performance street cars, Karts, etc....)-I think I would be in heaven.
Give me data acquisition, a laptop and a clipboard and I am happy, happy, happy!!
rayhuang is offline
Old 09-30-2003, 10:10 PM   #1107
RBLove's Avatar
Trader Rating: 72 (100%+)
D2 for the Big Ray. Give me the skinny on the diff cases.... Mine shipped Monday.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline
Old 09-30-2003, 10:15 PM   #1108
howard hudson's Avatar
geezzz sounds like the whole state of OHIO is going to be running warp cars
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline
Old 09-30-2003, 10:41 PM   #1109
speedxl's Avatar
axiom you can compensate for length via other adjustments.
length isnt the only way its just the easiest just just up steering not to be so agresive via tires springs or oil! i am sure you know how!
good luck ray i am sure you'll figure it out quickly! and that the d-2 is the ticket!
speedxl is offline
Old 10-01-2003, 12:45 AM   #1110
RBLove's Avatar
Howard,
Only the diff cases for me and possibly a top deck. Testing the top deck this weekend.
RBLove is offline
Closed Thread
warpspeed tc3 rcfreak24 Electric On-Road 1 04-13-2005 08:33 AM
Warpspeed TC3 ts R/C Items: For Sale/Trade 3 03-07-2005 11:22 AM
FS: X-Ray T1 Warpspeed SteveM R/C Items: For Sale/Trade 7 10-01-2004 08:05 PM
Exotic Chassis Sale: Warpspeed, Cuda, SPeedway Pal, Tech Racing dynamic_e R/C Items: For Sale/Trade 10 06-29-2004 08:38 PM
Bmi---irs--- Or Warpspeed JasonC Electric On-Road 1 12-02-2003 04:18 PM
