Closed Thread
Old 09-08-2003, 01:56 PM   #856
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
acloco,
Try running gold and silver w/ 40/30 oil.
Also, you don't need all that droop. Try about 2 mm over ride height all around. All that droop causes lots of front to back weight transfer and visa versa; you don't want a lot. BTW, more rear droop is going to give more weight transfer to the front since the rear end can lift up higher when the car dives going into a corner, making your problem worse. If it is losing traction entering a corner i suggest you take droop out.
Also, are you sure your rear diff isn't too tight? That could really do it. Make sure it is just tight enough so it doesn't slip, you don't need it any tighter than that.
Try running the rear camber link upper and outer. That should allow the rear end to roll more and will give more side bite.
If none of this works then there's something else going on not dealing with the chassis/suspension.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline
Old 09-08-2003, 02:05 PM   #857
forty6's Avatar
Originally posted by rayhuang
lem2-Chassis prep on a Carbon Fiber chassis is a labor of love. the smoother you can get it and the cleaner you can put the CA on-the more AWESOME your car is-to me anyways.
If you slide your finger along my 12th scale chassis and battery slots-its silky smooth. Take your time, make it pretty!!!
I usually start with 200 sand paper and finish with 600 on the edges. When I am done with that I use Q-tips to appply the CA on the edges. You will need a few Q-tips and you will also need to wear a mask and eye protection. The CA when it starts to dry can go gaseous and its nasty!!!
Also-the rounded edges are less likely to delaminate in a crash and also wont snag on carpet-making the car handle better at lower ride heights.
Guys,
When prepping the chassis, can you soak it in water before and while you are sanding. I want to minimize the dust since I heard that it is not good for you. Also, cheap dust mask will not work, only the $30 ones are safe enough. Any thoughts on this? Thanks.
forty6 is offline
Old 09-08-2003, 05:43 PM   #858
stonedgti's Avatar
Trader Rating: 15 (100%+)
acloco have you tried just lowering the D/R and steering ratio on your radio? I always do that first before I mess around with the set-up.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline
Old 09-08-2003, 05:45 PM   #859
stonedgti's Avatar
Also, where do you race? If you race at SpeedWorld, I can give you my set-up. My car is so dialed.
Old 09-08-2003, 08:23 PM   #860
RBLove's Avatar
Trader Rating: 72 (100%+)
I know this has been talked about, BUT.
What the advantages/differences in the Warpspeed diff cases? Also what is the cost?
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline
Old 09-08-2003, 08:37 PM   #861
RBLove's Avatar
Correction:
What "are" the advantages/differences
RBLove is offline
Old 09-08-2003, 08:46 PM   #862
RBLove's Avatar
NEVERMIND. Found the info. Gotta have a set
RBLove is offline
Old 09-08-2003, 09:36 PM   #863
CraigH's Avatar
Acloco-Set the rear droop to 2 or 3.Try 2 first then go to 3. Are you running mod or stock?
CraigH is offline
Old 09-09-2003, 12:28 AM   #864
I am leaving it to this forum......
Type me up a setup....and I will put that setup on the car.
Deadline is Thursday at 6.00 pm.
Stoned.....yes.....I race at SWR.
acloco is offline
Old 09-09-2003, 01:36 AM   #865
stonedgti's Avatar
acloco:
Here is my setup:
Front
standard front tower
2 degree castor
2 degree kickup
0 toe in
0 camber
45 weight oil in shocks
gold Springs
shock mounted on inner most hole
links are on inner top hole.
losi steering knuckles
one way installed
no sway bar
6 droop
Rear
R+3+2 block
-2 degree camber
30 weight oil in shocks
silver springs
links are inner top on the shock tower and upper outter on hub carrier
4 droop
Try this out and also mess around with your radio.
Old 09-09-2003, 01:10 PM   #866
stoned....are you running the warpspeed chassis???
...hehehe...and what is your real name?
acloco is offline
Old 09-10-2003, 10:09 AM   #867
Default WARPSPEED RACING
RACERS:
Our website is currently under construction.
But, for more information on WARPSPEED'S Line of PRODUCTS and PRICE LIST, go to www.warpspeed-racing.com
Thank you for your interest in WARPSPEED RACING.
Have a Wonderful Day
Mr Warpspeed is offline
Old 09-11-2003, 06:00 AM   #868
wheelmanST's Avatar
Send a message via AIM to wheelmanST
can i get some more info on your batteries? looking for new batts for the winter....yours matched at 20 or 30 amp? Your stuff looks very nice. may have to get a demon...just dusted off the old tc3 for the winter.
wheelmanST is offline
Old 09-11-2003, 06:40 AM   #869
We match at 30 amps. The numbers can run 410-425.
Average voltage is 1.175 to 1.88.
Old 09-11-2003, 06:12 PM   #870
Mike Haynes's Avatar
I have heard a lot of good stuff about the demon, and i cant wait untill i can get mine (Hopefully in time for cleveland this year)!
Mike Haynes is offline
Closed Thread
warpspeed tc3 rcfreak24 Electric On-Road 1 04-13-2005 08:33 AM
Warpspeed TC3 ts R/C Items: For Sale/Trade 3 03-07-2005 11:22 AM
FS: X-Ray T1 Warpspeed SteveM R/C Items: For Sale/Trade 7 10-01-2004 08:05 PM
Exotic Chassis Sale: Warpspeed, Cuda, SPeedway Pal, Tech Racing dynamic_e R/C Items: For Sale/Trade 10 06-29-2004 08:38 PM
Bmi---irs--- Or Warpspeed JasonC Electric On-Road 1 12-02-2003 04:18 PM
