Warpspeed Racing
#691
thanks trinityracinnut
i have this question about stock motor brushes. i just want to know if drilling a whole in the center of the brush will give me more rpm. or will it not.
#693
Originally posted by Axiom5B
I have a friend who uses the center oneway and likes it on carpet.
Ride Height:
Lower = lower CG; corners better; doesn't have to transition as much weight so transitioning is better. Just don't go too low because then the chassis may scrape the surface. For foam tires on carpet I usually stick with 4 mm, unless its like a 5 mm rule. So basically the lower, the better. The exception is on something like a semi-bumpy/rough asphalt surface where you may need more ground clearance, then you should run more, but in general, lower is better.
Ride Height:
#696
So, any luck with the 2.5mm chassis or is it still in testing, I can test one for you Seriously though, I'm interested in the 2.5mm kit if it turns out the same or better than the 3mm. Either way I'm getting one
#700
I did the hunting for you guys for the center one way as i need another one also.
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=984
#705
DEMON 2
Well as some of you may've heard already, there is a new, updated, and better than ever DEMON coming it. It's called the Demon 2. New features are short wheelbase (250mm) that makes the car extremely smooth and feels as nimble as a 12th scale car from what i hear. The Demon 2 will come with the same hardware as the Demon, just shorter chassis and top deck. This shorter wheelbase requires the use of the Nitro TC3 center driveshaft. The Demon 2 will be especially good on tight courses, but will excell on any course.
In the attached picture, the batteries are not yet centered in teh chassis, as it is a prototype, but the production version will have the centered pack just like the Demon.
The DEMON 2 will be out in late September or October.
