Closed Thread
Old 06-06-2003, 09:33 PM   #436
I think the old cyclone has less on res. than the gt-7. I have noticed that whenever I get a brand new speedo, the car seems punchier with the exact same profile. I spent some time in school for electronics years back and remember that any circuit that sees high current flow eventually builds resistance. If memory serves me he used the analogy of a road. Its smooth and great when brand new, but gets rough and bumpy as traffic takes its toll. I believe that fets eventually build up with resistance and rob power. It is a good practice, in my opinion, to get a new speedo once a year. I think that Keyence has the best performing speedo right now. But, like Stephen said, you get what you pay for and they aint cheap.
Art Jensen is offline
Old 06-06-2003, 11:06 PM   #437
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
WOOHOO!! just finished my DEMON!!!!!
This car is sweet...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline
Old 06-07-2003, 07:01 AM   #438
howard hudson's Avatar
told you you would be in mad wrench mode when you recived your package
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline
Old 06-07-2003, 09:37 PM   #439
Default Re: diffs adjustments
Originally posted by HARLEY
how tight or loose the ball diffs should be and how those adjustments at each end affect the car?
If you run the front loose, you will have lots of off power steering, and very little on power steering. Run it tight and it will be the opposite. The rear is just the opposite. I usually run the front a little tighter than the rear unless there is just sick amounts of traction. Then run them about even. Good luck finding the feel your looking for.
Old 06-07-2003, 11:38 PM   #440
Well my first race day with the car was full of glitches. I finally got the car working good after a few packs. Sorry howard, your setup probably didn't work well because no one bothered to sweep off the track before they sprayed down the soda....we were racing mod as well. I broke in the main after a glitch sent my car full throttle into a pipe.
However my setup got decent, so for those of you who race on low-bite tracks here it is:
Front:
Blue springs
35 wt oil
2 piston
second hole on tower, outer hole on arm
stock swaybar
droop 6 on gauge
F-0 block
4 degree castor blocks and losi knuckles
-1 camber, 0 toe
camber link upper outer, rear shock tower
no oneway, VERY tight diff though
Rear:
silver springs
40 wt oil
2 piston
outer hole on tower, outer hole on arm
no swaybar
droop 3 on gauge
R+3-0 block
losi rear hubs, inner hole on hub
-1 camber, 3 toe
Wheelbase middle
5 mm ride height all around
Losi Alfa body
Take Off CS-27 (premount) tires
This was for mod, should work good for stock too.
USVTA Member #211
Old 06-09-2003, 06:19 AM   #441
thanks for the info guys.
HARLEY is offline
Old 06-09-2003, 10:19 AM   #442
Default Race Report
Saturday - TQ and finished second (bad start) in Expert stock at Citrus .
Sunday - There weren't enough people to have a expert class so it was mixed Expert/Intermediate. I was told that two of the drivers were pro level. Qual 1 - got spun in the first turn and was in last place. Past everyone in the first two laps except first place. Closed on him a little but finished second. Qual 2 - Started second to last position. Fought through traffic and won but time a little short of TQ. Heartbreaking ending...A-Main - had my best pack, best motor, fresh tires. Put my car down to start the race...hit the throttle...car went backwards. Soldered the motor leads backwards and couldn't fix it before the race started . Magic Man was there two, though running his Demon and picked up the slack. He got his car dialed in in the second Qual and had a good battle for first place in the Main, but finished second only behind the pro guy. Since he was considered a pro, Magic was declared the official winner. Anyway, the car was great. This track is known for it's poor traction. The setup I got from Howard Hudson still kicked butt even on the loose track. I only made a small change to add some steering. I put green springs on the front. Next time out I'm going to try the car without the upper deck.
Vic - any new updates on the split upper deck?
DOTMAN is offline
Old 06-09-2003, 01:22 PM   #443
Default WARPSPEED RACING
Dotman/Magic:
Great Job Guys. The upperplate is available now.
Mr Warpspeed is offline
Old 06-09-2003, 01:28 PM   #444
Here is a picture of the new cut-out upperplate
Old 06-09-2003, 09:32 PM   #445
Hey all members of the Warp. team, I am testing the car out on carpet with foams this week. I will report back with a dialed setup. Art, victor tells me that you're looking for a good setup, i'll get on it .
USVTA Member #211
Old 06-11-2003, 09:29 PM   #446
Ok guys i got it. Those who run a Demon i got the setup for carpet with foams. For the team guys...its dialed, but even if you like your car different than me, it's a great starting setup. Easy to drive fast...stock and mod.
Front:
Yellow spring
70 wt oil
#2 piston
Reg. Front tower, outer hole
outer hole on arm
camber link upper outter
Camber -1
Toe 0
F-0 block
Droop 6 on AE gauge (on the setscrew stub)
stock swaybar
spool
Rear:
Copper Spring
60 wt oil
#2 piston
outer hole on tower
camber link upper inner
outer hole on arm
camber -1
Toe 2
R-2-0 block
Droop 5 on AE gauge
no swaybar
Outer/upper hole on hub (AE hub)
Tires: Plaid/Purple
Body: Losi Alfa, Proto stratus 2 will work better on high-bite.
Ride Height: 4.5 mm all around
Solid upper deck
USVTA Member #211
Old 06-12-2003, 08:15 AM   #447
Axoim5B, i will try the set up this weekend keep you guys posted
HARLEY is offline
Old 06-12-2003, 09:11 AM   #448
Cool, i ran 4.5 mm ride height only because you never know if the race people are gonna suddenly switch on ya like they did at cleveland last year and go to 5 mm. This way you only go up 1/2 mm and it doesn't affect things nearly as much. And if they keep the usual limit like they normally do i can drop down to 4 mm for better handling.
USVTA Member #211
Old 06-12-2003, 04:59 PM   #449
man wish we had a carpet track here in sunny so cal. carpet is way ugly traction!!!!!!!!!
Old 06-12-2003, 08:36 PM   #450
carpet rocks, nuff said.
USVTA Member #211
Closed Thread
warpspeed tc3 rcfreak24 Electric On-Road 1 04-13-2005 08:33 AM
Warpspeed TC3 ts R/C Items: For Sale/Trade 3 03-07-2005 11:22 AM
FS: X-Ray T1 Warpspeed SteveM R/C Items: For Sale/Trade 7 10-01-2004 08:05 PM
Exotic Chassis Sale: Warpspeed, Cuda, SPeedway Pal, Tech Racing dynamic_e R/C Items: For Sale/Trade 10 06-29-2004 08:38 PM
Bmi---irs--- Or Warpspeed JasonC Electric On-Road 1 12-02-2003 04:18 PM
