Warpspeed Racing
Closed Thread
Old 04-18-2003, 11:03 AM
  #241
I have never really tried them but TIR racing makes titianium cvds and axles for I think around 30$ a pair. They are light and really strong you should thik about buying some. They are distributed through Shumacher.
stephen Baker is offline
Old 04-18-2003, 01:43 PM
  #242
ohhhhhh! TIR Racing is here in the UK. ill have to look into it.
HARLEY is offline
Old 04-18-2003, 04:19 PM
  #243
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
does anyone have a web addy for TiR the one I have doesn't work anymore.
Jon
Jon Carlson is offline
Old 04-18-2003, 04:44 PM
  #244
The web address is www.titaniumracing.com
But they had a fire in their factory so the shop is down for a couple of weeks.
Old 04-19-2003, 09:00 AM
  #245
Default The car ran awesome
I ran yesterday with my Demon car and it was kicking ass. I purposely ran an MVP motor to get some idea of what it will run like. Practice for the On-Road Nats. I was amazed at the amount of power difference there is between the Monster and the MVP. The monster motor has so much more power than the mvp. I won the race becuase the car ran like a dream but I had no power. I am trying to get some of the guys to practice with the MVPs.
The Demon car ran great this was my set up.
One way
F+0
50w
rear shock tower using body mount holes
gold spring
outside hole on new front arm
no sway bar front
droop 6
losi steering nuckles
4 degree caster
rear sway bar
gold springs
40w
3+0+0
droop 4
losi hubs outside hole 0 degree toe in
out most hole on shock tower
short wheel base
This set up has a lot of steering and really is fast
rangulo is offline
Old 04-19-2003, 11:28 AM
  #246
Are you talking about the nats in June in N. Caroilna?
By the way w/the motor comment your kinda leaving yourself open for comments of your past.
Old 04-19-2003, 03:48 PM
  #247
Default Steering rack
I have been using the nitro rack but what are you guys using and Why? Nitro or electric steering rack...
rangulo is offline
Old 04-19-2003, 05:39 PM
  #248
I have been using the nitro rack b/c it is a lot easier to maintain(don't have to clean it out) and also it seemed to calm the steering down and not be so aggressive entering the turns. It helped smooth out my driving.
Don't forget if you guys use the nitro rack. To get full steering throw you must grind away some material from the rack swing arms.
You still tell me what nat you are practicing for.
And Rangulo what does the losi steering knuckles and rear hubs do?
Old 04-19-2003, 07:39 PM
  #249
the rear hubs you can get them in different degrees. so another words if you run assoc 3 deg toed in the rear and you put a half deg losi hubs backwards, you will run 2.5 deg per side or if you run them the right way then you will run 3.5 deg on each side. i am pretty sure you can get them up to 2 deg, but dont quote me.
i run the ntc3 swing rack. it is just like stephen said it is alot more smoother to drive. it is not as aggressive as the regular rack and it is low maintanence.
HARLEY is offline
Old 04-19-2003, 07:46 PM
  #250
rangulo, well if you are running 3 deg toed in the rear and losi is
0 deg what is the advantage between the assoc and the losi hubs?
HARLEY is offline
Old 04-19-2003, 08:29 PM
  #251
Brian McGreevy's Avatar
It allows you to change the roll center because the ball studs are mounted vertically.
Brian McGreevy is offline
Old 04-20-2003, 06:38 PM
  #252
What/How does the roll center adjust on your car?
I never really found out or researched it b/c I have always had a TC3 and it doesn't have that adjustment w/stock rear hubs. When I tried to look into it and read about it I couldn't find anything on rollcenter adjusting.
Old 04-20-2003, 07:02 PM
  #253
Fred Hubbard's Avatar
Actually you can adjust the roll center on the stock TC3 by just moving the camber links up or down.
Fred Hubbard is offline
Old 04-20-2003, 07:15 PM
  #254
Thanks, it doesn't really say anything in the AE book.
How does this adjust the car, handling wise?
Old 04-20-2003, 07:22 PM
  #255
With the losi hubs the ball studs are mounted vertically so you can put spacers under them and therefore adjust the roll center more than you can with the stock hubs.
