Keyence Rapida Pro >
Keyence Rapida Pro
Keyence Rapida Pro
Old 02-12-2007, 10:23 PM
surrealmaterial's Avatar
Default Keyence Rapida Pro
Hey,
Ive got a Keyence Rapida Pro and in the instruction manual it says i need to put capacitors on the motor between the + and - terminal, between the + and the motor case, and between the - and the motor case.......why do i need to do this and is it necessary? it also says "make sure to connect the included noise-suppression capacitor to the motor, If not you may damage the ESC"............has anyone ever run it without them on and what has happened?
surrealmaterial is offline
Old 02-13-2007, 06:01 AM
t4m1y4niac's Avatar
Originally Posted by surrealmaterial
Hey,
i have couple friends using rapida pro and they are not using any pwr cap and it works very well
t4m1y4niac is offline
Old 02-13-2007, 06:46 AM
Ian S's Avatar
The capacitors your are describing arent power caps there interference stopping caps. I wouldnt think running without them would damage the esc but you may get interference. What motor is it? most have them built in nowadays.
Ian S is offline
Old 02-13-2007, 06:54 AM
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
the keyence rapida pro was used to TQ an win the snowbirds sunday in Stock foam TC.
schreff TQ
L fairtrace Won
DENNIS STORTI is offline
Old 02-13-2007, 01:06 PM
at the moment i am using a 540 motor but soon i will be using a CO27 stock motor........
Old 02-13-2007, 01:11 PM
teamgp's Avatar
schreff TQ
L fairtrace Won
Also won the 19T foam TC class G main.
teamgp is offline
Old 02-27-2007, 01:51 AM
i just got my keyence rapida pro, and the guy i bought it off gave me a 25v 2200uf capacitor, is it ok to run it with this capacitor?
