Old 03-17-2003, 06:46 PM   #1
skibum989's Avatar
Default Stripped Screw Removal...
Can anybody point me in the direction of a tool that will remove a screw with a stripped head from the bottom of my chassis? I know that most of the time you can just grab a Dremel and slot the screw head, but the screw is countersunk and I don't want to fudge up my nice graphite chassis . Please help, this is driving me crazy!
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Old 03-17-2003, 06:49 PM   #2
Send a message via AIM to SteveA
Craftsman makes a striped screw remover, havent tried it yet.
http://www.sears.com/sr/product/summ...id=00952154000
SteveA is offline   Reply With Quote
Old 03-17-2003, 07:10 PM   #3
popsracer's Avatar
If the Driver slot(s) are not completely rounded. There is a Anti-Camout compound you can buy that will grab the screw much tighter. Should be able to get it at a decent Hardware supply Store. Otherwise it's Dremel time.
popsracer is offline   Reply With Quote
Old 03-17-2003, 07:28 PM   #4
Neil Rabara's Avatar
There is also something called an "easy out". You will need a reversible drill though. How it works is you drill down the center of the screw with a bit, then using the reversible feature of the drill use the "easy out". This will grab the screw from the inside of the drilled screw and back it out not hurting your graphite chassis.
Neil Rabara is offline   Reply With Quote
Old 03-17-2003, 07:52 PM   #5
Or you could get a left handed drill bit, as soon as it starts bitting into the screw it will back right out.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-17-2003, 08:16 PM   #6
KevanB's Avatar
Are there any other ways for a reeeaaallly small screw? I have these very small screws that hold the battery pack thingy down. They are very small and the alen wrench cannot remove it.
What do you guys suggest?
KevanB is offline   Reply With Quote
Old 03-17-2003, 08:18 PM   #7
Is this on your XXX-sgraphite??
Old 03-17-2003, 08:42 PM   #8
popsracer's Avatar
Default 'EASY OUT'
I don't think they even make an 'Easy-Out' for screws that small (3mm?) Maybe a 1/8" left-handed bit, but in Plastic/Graphite it would be risky.
Try a VERY sharp pointed set of Diagonal wire cutters to grab the broken screw with. This will work if there is enough of the screw left to grab on to.
Old 03-17-2003, 10:12 PM   #9
skibum989's Avatar
Thanks for the advice, my dad says we have some easy-out bits. If that doesn't work, I might try that Craftsman set. Thanx again!
Ryan Robison
Old 03-17-2003, 10:21 PM   #10
-CriMinaL- |RC's Avatar
Send a message via AIM to -CriMinaL- |RC Send a message via Yahoo to -CriMinaL- |RC
try putting CA glue in the head then glue your tool into the screw .. leave overnight then unscrew in the morning.
-CriMinaL- |RC is offline   Reply With Quote
Old 03-17-2003, 10:33 PM   #11
Default Re: 'EASY OUT'
I have one, got it from Pepboys.
Old 03-17-2003, 10:54 PM   #12
You can also use normal drill bit to drill out the head of the screw. Use a drill bit that's about the same size as the screw and drill through the head until it head seperated from it's body. Now you have a chassis safetly removed from the stripped screw but the remaining part of the screw still struck in another parts. If you don't drill too much then some of the thread will stick out of that part. Use vise,locking plier or whatever to grap that sticking thread and unscrew it out. BTW the drilling process produce a lot of heat that may melt some chassis so you should use a sharp drill bit with some lube.
Another way is using a screw remover bit. I think that mine was made by Vermont. The smallest size that intend to use for large screw work just fine for 3mm countersunk screw but you have to pick the right size drill bit that slightly larger than the tip of the remover.
tifosi is offline   Reply With Quote
Old 03-18-2003, 01:48 AM   #13
Send a message via ICQ to JesseT
If you have stripped the hexagonal solt of the screw I guess the screw is aluminum? In that case you just take an allen key of the next size (proper, not with the L-shape) and hammer it in and unscrew the screw. Very easy with aluminum screws.
JesseT is offline   Reply With Quote
Old 03-18-2003, 06:24 AM   #14
Stripped screw??...ehhhh just throw the whole car away and buy another...LOL!!!! J/K!!!
Old 03-19-2003, 08:18 AM   #15
KevanB's Avatar
sorry if I wasnt specific enough. It is the receiver battery case in my XXX-NT that screws down the cover. BTW it is a very tiny screw. help?
Removing Stripped Screw? coolguy5 Nitro On-Road 3 07-21-2007 02:03 PM
stripped pinion screw AZNracerx1989 Rookie Zone 3 08-02-2005 11:31 PM
Stripped Screw DIMO Electric On-Road 11 06-07-2005 03:57 PM
stripped screw ntc3freak Nitro On-Road 23 09-21-2004 05:35 AM
Stripped Screw RCDoon Electric On-Road 1 04-01-2003 09:11 AM
