What's the difference 007 rubber vs.foam >
Old 02-11-2007, 03:58 PM
gurumods's Avatar
Default What's the difference 007 rubber vs.foam
Xray has two models of the 007.The US & the EU edition.What parts are different cause i have the opportunity to buy some shocks and arms for my 07 US and these parts i am looking at are EU.
Is it just chassis or is it more than that.
gurumods is offline
Old 02-11-2007, 04:00 PM
not being a xray guy, but i think the differences are the top and bottom plate, one has thicker shock towers, one comes with ball diffs all round the other with spool or one way. i think thats it. Correct me if im wrong
maco334 is offline
Old 02-11-2007, 04:16 PM
Trader Rating: 14 (100%+)
Hi,
other than the one-way and the four stsnd offs. the chassis and upper deck are different (#301122 and #301178). all I bought was the upper and lower chassis plates to convert one of mine over.
TimXLB is offline
Old 02-11-2007, 04:55 PM
gurumods's Avatar
OK.I am gonna get some shocks and cvd's and axles.I could not imagine the whole car being different,but i just wanted to play it on the safe side and ask first.
gurumods is offline
Old 02-11-2007, 05:51 PM
R.Dalnogare's Avatar
im not sure but i think the us arms are extra hard and the eu is standard or something like that
R.Dalnogare is offline
Old 02-11-2007, 07:10 PM
Team Speedy's Avatar
Trader Rating: 52 (100%+)
Mainly the chassis is 2.5mm for the Euro edition with hard arms, front oneway, different top deck and it does not come with the standoffs
Carpet edition has, 3.5mm chassis, more solid top deck, extra hard arms, duel diffs (new material not the factory lighten specs) and includes the standoffs as well.
Check out http://www.teamxray.com and you'll be able to find the specs and a brief tour inside the web page.
Best of luck-
Team Speedy is offline
Old 02-11-2007, 07:22 PM
gurumods's Avatar
Thanks Speedy.I really want the parts that get smacked a lot(especially with my driving) like the outer edges.cvd's,uprights,steering arms and such.I am not purchasing a whole car,so i don't have to worry about getting stuck with all the EU parts
gurumods is offline
Old 02-11-2007, 07:57 PM
The Eu DOES come with standoffs. I own both cars.
R/C Anonymous is offline
Old 02-11-2007, 08:05 PM
If your just buying indiviudal parts, nothing has changed significally to the outter drivetrain. Everything is the same expect in the USA version you get extra hard arms (great if you happen to run carpet, on my ride currently). If you run the Euro you get Hard arms (Stnd. in the T2 kits) The running change that I have heard of was in the CVD's they rounded off the lip of the axle coupler so that getting a CVD out wasn't a pain in the rear.
Hope that helps
