Old 03-17-2003, 04:55 AM   #1
teamsherman's Avatar
Default Question????
Just a question that i think alot of people would like to ask but are too shy to ask...
Do Tamiya plugs on battery links and those steel bullet style tamiya motor plugs make any difference to performance i.e, acceleration or voltage/amps intake????
please help me out as i am sceptical about changing all my plugs over, but i want to get the best peformance i can out of my equipment.
teamsherman is offline   Reply With Quote
Old 03-17-2003, 05:02 AM   #2
Cole Trickle's Avatar
Changing the usual Tamiya style connectors to good quality connectors, makes a big difference. I wouldnt be in doubt at all.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-17-2003, 05:28 AM   #3
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
The Tamiya style connectors are very inefficient. Dun use them if you can use something else such as Deans connectors.
I have heard stories that the Tamiya connectors have such hight resistance that when used with modified motors, the IR heating from the higher current drawn actually welded the two sides of the connectors together
Nope, have not verified that story, too costy to prove if its is true
NightKidZ is offline   Reply With Quote
Old 03-17-2003, 05:48 AM   #4
sosidge's Avatar
No, it's true, Tamiya connectors can melt together.
Old 03-17-2003, 05:50 AM   #5
Default Right?
So you guys are saying that i will be faster with deans or corally plugs???? and to ditch the tamiya plugs???
Old 03-17-2003, 06:25 AM   #6
Definately ! Try touching your connectors immideately after you've driven your car... I'll bet they are warm/hot. This means wasted energy, which you would like to go to your motor...
Old 03-17-2003, 06:45 AM   #7
Default Yep Yep
Thanx guys, my mind has been made up, i am changing plugs.
Old 03-17-2003, 07:15 AM   #8
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Cole: is right on...
It takes energy to make heat...Where do you think that energy comes from?
Tres is offline   Reply With Quote
Old 03-17-2003, 07:49 PM   #9
YEP!! take it from aguy that has actually seen a fire coming from these plugs!!!!1
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
