ko propo 2413 ics servo >
Old 02-07-2007, 10:33 AM
stephen hilton's Avatar
Default ko propo 2413 ics servo
hi guys i have recently bought this servo, i have never really liked it as it was always rough and notchy when it was turned i have just turned it today after a big race at the weekend and its 100x worse! its rough and notchy but it seems to stick in diffrent places
is it broken or are they meant to be like this?????
stephen hilton is offline
Old 02-07-2007, 11:02 AM
Trader Rating: 14 (100%+)
Stephen:
Hi,
I have a few of the KO 2413 servos and really like them. the low profile is nice and I felt it worked better than the 9550 I had.
as for the feeling you posted about. are you trying to turn it by hand with a servo saver?? it could be the servo saver working and then catching making the 2413 feel like you posted. I hardly ever move any of my servos unles it's under power from a Rx pack. I feel it's not all that good for them.
TimXLB is offline
Old 02-07-2007, 11:14 AM
Try loosening the servo case, but not too much. If the case is over-tightened, the gears will bind.
KO PROPO Staff is offline
Old 02-07-2007, 11:47 AM
ok will do but how do you know if your servo is broken by not turning it?
Old 02-07-2007, 11:49 AM
It should turn freely. If not, either the case or the one plastic gear is damaged.
Old 02-07-2007, 11:53 AM
by hand it dosent turn freely it sticks alittle in places but the only weird thing is that it was like that since i bought it
Old 02-07-2007, 04:06 PM
Check the case. Mine was a little tight from new.
MattW is offline
Old 02-07-2007, 05:04 PM
rampal's Avatar
unscrew the 4 screws half a turn.... mine gets much better and faster after this. you should be able to see the rubber seals ease a little. Check for the case to be even (same space between parts) all round.
cheers,
rampal is offline
Old 02-08-2007, 03:25 AM
i havent used the rubber seals does this matter?
Old 02-08-2007, 04:22 AM
rampal's Avatar
what do you mean? They are already there.... if you took them out, that means that you're squeezing the gears....
there must be 2 square rubber gaskets (or seals) one for each joint on the case, plus 4 o'rings, one in each screw... what I'm saying is to unscrew only half a turn each screw, assuring that all the pieces are parallel, otherwise you're loading on side of the gears more than the other, thus bending the stuff inside... this way you make the gears run more freely...
rampal is offline
Old 02-08-2007, 12:03 PM
HANG ON which screws do you mean the ones on the servo or the ones that attached the servo to the car?????????????????
Old 02-08-2007, 12:04 PM
The screws that hold the servo case together.
Old 02-08-2007, 12:38 PM
arrrr right i have dont that but still no change i loosend the screws that hold the servo to the car and it freed up a bit
Old 04-21-2007, 12:41 AM
I bought mine 20 days ago in Japan
it had the case screws already loose (case almost open!), but was already notchy moving by hand, I managed to close the screws and tried it - not a lot, just 4 packs, it seems to work fine ('til now) even if is still rough and almost impossible to move by hand.
bandi is offline
Old 04-21-2007, 04:07 AM
Default Same
I brought two of these. One acted exactly as you described. Backed out the screws all fixed
Pony is offline
