Old 03-15-2003, 06:11 PM   #1
Send a message via AIM to AssociatedRacer
Default Soldering Batteries
Hey guys, I have soldered 4 batteries already. Im not really proud of the quality. I know you need at least a 60watt iron right? With a chiseal tip? I have a 40watt well iron station. Also For the shrink wrap do I just put it on the cell and blow dry it?
AssociatedRacer is offline   Reply With Quote
Old 03-15-2003, 06:18 PM   #2
CaptnKrunch's Avatar
hi AR... yes a 60 watt would be better for the batteries better yet something with adjustable heat ,, the hotter the better for faster work,,, to much prolonged heat from a not hot enough iron can damage your cells.... shrinkwrap wise... a blow dryer should work fine .. just put it on HIGH Heat
CaptnKrunch is offline   Reply With Quote
Old 03-15-2003, 07:10 PM   #3
Hey, forget about this thread...I just found this site:
http://www.promatchracing.com/howto.html
check it out if you need help...
Old 03-15-2003, 07:53 PM   #4
Neil Rabara's Avatar
Don't forget to scratch the surface of the cell before you solder. It will help the solder stick better.
Neil Rabara is offline   Reply With Quote
Best Soldering Iron for Batteries? RCpurplecow Electric On-Road 37 05-02-2008 03:13 PM
soldering batteries SRBMOJO Electric On-Road 9 07-06-2007 03:11 PM
Soldering Batteries tc4 Australian Racing 10 09-23-2006 11:41 PM
Soldering batteries - help D_o_S Electric On-Road 21 02-27-2006 07:41 PM
Soldering batteries - gap or no gap? D_o_S Electric On-Road 11 02-26-2006 10:11 AM
