Checkpoint or Orion Oscar?
Hi.
I'm about to buy a bunch of mod motors for my national racing this year and im torn between two types of motors.
Im running 5 cell at the 1350g weight limit and brushless is kinda out of the question because it will be too heavy.
So i cant decide between a Checkpoint motor and a Team Orion Oscar Jansen Motor.
Ive had problems in the past with Orion V2's that dust gets in the brush hoods easily and causes problems. But ive never tried a Checkpoint motor.
I want obviously the fastest motor i can so i will be using very fast winds but i need the motor to have good wear rates aswell. I would assume the checkpoints brushes also last a long time?
any help anyone can give me to make my mind up with be much appreciated.
thanks
thanks
Are you running in outdoor medium/large size track?
If so... even if you are at 1450 weight with a Brushless, the power advantage of the brushless over the brushed would be so great that it would outweight the extra 100 grams.
Also don't be so sure that brushless is much heavier than brushed. If you include the shotcky's and capacitors required for brushed you are not that far off the weight of a brushless configurations. Difference would be max 20-25 grams, with the brushless being heavier.
I have tested 5 cell brushed and brushless and the brushed doesn't have a chance. Only in a very small indoor track the brushed can compete against the brushless.
Now, if you insist on buying brushed, both motors, Orion OJ Edition and Checkpoint are good.
I would go for the Orion OJ Edition simply because no soldering is required anymore and this makes life soooo much easier.
Regerding dirt getting inside the brush hoods.. this can happen to all types of motors.. you need to do some cleaning at some point regardles of the design.
More details on the OJ edition endbell you can check in my blog where I have some close ups of how well the endbell is designed.
Just click on my signature and scroll down..
thanks John,
I will be running it on the medium to large british tracks
I wasnt sure whether brushless would give an advantage mainly because of the weight but you arent the first person to suggest to me that it would.
As with the brush hoods, i accept that some cleaning is required but i've had brushes get stuck in the middle of a race straight after a strip down.
It just seems to be a little more common on the V2 motors.
I will investigate more in brushless as well.
my vote would also be fore the Oscar jansen motors. I really like the fact that the endbell uses a plug compared to soldering onto the tabs
don't you get far more runs on the checkpoint motor brushes, than you do on the v2 brushes, or with the new smaller 3.8mm orion brushes are we seeing similar wear rates?
Sleighty
Well this is pretty much the case now with brushless. I have seen the majority of the outdoor tracks in U.K. and going brushed would be a suicide. Its THAT big of a difference...
Its time you invest in a brushless system..
I must say.. I am still surprised you had problems with dirt entering the brush hoods and blocking the brush movement.
I cannot think of a place with more dust than the track we race at as the non stop sunny weather prevents the surface from being clean..
.. and yet I never had any issues with brushes getting stuck.
anyway.. it is time for brushless and the end to your headaches.
The OJ motor is the current World Champion in TC.
Also if your looking for Brushless the new Vortex BL motor that we have coming soon is also the current European Champ.
Just putting that out there.
Originally Posted by Sleighty
thanks John,
But it´s your money, so...
just like to thank everyone for their input, i already had a brushless and since doing the testing with 5 cell ive found that you guys are indeed correct.
Brushless it is then
Hey Paul,
Which brushless controller are you running? I might have a prototype for you to try out?
T
T
Originally Posted by BigDaddyT
Hey Paul,
T
T
