Old 11-17-2001, 07:28 PM   #1
Alvin's Avatar
Default Running RC2400's more than twice a day?
Is it ok to run RC2400s more than twice a day? I have just bought my first RC2400, only charged it once for run and then discharged it via my tamiya discharger, then trayed it in an integy activator x. I would like to know what is the proper method to handle them, if they can be used like twice a day (I had to cycle between 2 3k batteries for my last race!!)
Many thanks. Would also appreciate charge current and delta peak information
Regards,
Alvin
Alvin is offline   Reply With Quote
Old 11-17-2001, 08:56 PM   #2
Regional Moderator
daniz24's Avatar
i think that's okay... but make sure the batt is cool enough, before second or third charge..
daniz24 is offline   Reply With Quote
Old 11-18-2001, 08:22 AM   #3
Cole Trickle's Avatar
I run my Sanyo 2400 for twice and sometimes three times a day.
Ensure they cool down, before charging again.
I charge them at 6,5 amps for better punch (I'm running stock class.) I also use a pulse charger for better punch.
I discharge them or drive them till they drop, between charges. Between sessions (racing/training), I discharge them fast, then equalize them. That's all. I've doing this for the 6 month I got the pack and they work real fine.
Cole Trickle is offline   Reply With Quote
Old 11-18-2001, 08:53 AM   #4
Regional Moderator
Darkseid's Avatar
JUST MAKE SURE THEY COOL OFF!
Aside from that, feel free to do it. I do, without any side effects. And don't worry about people saying it has negative effects, I have been doing it since I got my 2400, and they still run strong and long.
BUT...................................
When I say let them cool down, I mean NORMALLY!!! NOT that "put em' in a plastic bag and stick in an icy cooler" crap! Let them cool down normally and they will be fine for using them multiple times.
TLR 22...Tamiya F104...
Old 11-18-2001, 09:17 AM   #5
Aurra Sing's Avatar
Yep, several of my local drivers charge their Ni-Cd's twice a day, letting them cool between charges. They claim it gives them more punch on the second charge, but a few seconds less run time.
Aurra Sing is offline   Reply With Quote
Old 11-18-2001, 12:32 PM   #6
That's right, the second run got more punch.
Old 11-18-2001, 12:37 PM   #7
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I use my 2000 packs twice a day in practice...But not my 2400s. I let them cool down for about 3 hours at least before running them again, that is after I have left them on the tray for 30 minutes. They seem to work fine still, and I still use one of them for racing.
Speedo is offline   Reply With Quote
Old 11-18-2001, 08:37 PM   #8
Trader Rating: 69 (100%+)
when letting the batteries cool down between cycles, is it ok to use a cooling fan? without a fan, my batteries usually cool down in an hour. if i use a fan, my packs cool down in about 20-30 minutes. i use my 3000s twice a day and ive read that there should be at least 1 hr rest inbetween cycles. but i dont have enough time to charge in between our race heats. will this affect battery life? or is it fine to use a cooling fan? thanks for any info
marvi is offline   Reply With Quote
Old 11-18-2001, 08:40 PM   #9
Moderator
Speedo's Avatar
Mariv-you should really let the cool down for at least 2 hours. Even though they feel fine on the outside, the cell inside can still be warm, so when you charge again, you are potentially hurting your cells.
Old 11-18-2001, 08:57 PM   #10
Simon K's Avatar
Wink
I was certainly abusing them yesterday
I tried to get that bit of "Second charge" extra voltage by charging them for 10 minutes, flattening them at 30 amps then charging them again after a short cooldown period.
My cells aren't that flash(Orion "Club spec") in fact they'd be pretty weak compared to whats currently available.
Simon K is offline   Reply With Quote
Old 11-18-2001, 09:21 PM   #11
Alvin's Avatar
Thanks for the info dudes! Keep 'em coming in! I was considering getting some 2400s for stock racing, and 3000s for mod. But I can't have THAT many batteries
Old 11-18-2001, 09:31 PM   #12
thanks speedo. i guess ill have to get another pack. i have difficulty charging in between heats because of the time constraint.
Still running a B3? Bikerbob Electric Off-Road 25 04-10-2008 05:40 PM
an 480 out-running BL on my SB... ny Electric Off-Road 2 03-17-2008 08:38 AM
B and B running on 1/21??? polesitter61 Florida Racing 1 01-16-2007 06:07 PM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 08:28 PM
Who is running what?? Giuseppe Canadian R/C Scene 19 03-16-2004 08:07 PM
