Team Much More tires >
Old 02-03-2007, 04:56 PM
PitCrew's Avatar
Default Team Much More tires
So, i'm curious to know what other peoples experience are with these tires.
I have tried two sets of them over the last two weeks and had the following experience:
The tires were Great for 2 runs, then they went downhill. To the point that they are one night tires IMO. I ran the tires brand new in the first qualifier, and they were fantastic, then had some issues and didn't finish the other two quals, then in the main with probably 12 minutes track time on the tires they were crap. (six minute heats and mains in 19t on high grip Asphalt)
I am using the sauce technique of cleaning with Buggy Grip, the applying Tire Tweak after wiping them clean.
PitCrew is offline
Old 02-04-2007, 07:07 AM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Are the wheels vented? I ran some of a different brand that where premount and the wheels were vented. They work fine.
And another of the same kind self glued but not vented. They worked terrible. I gave them away before venting them.
UN4RACING is offline
Old 02-04-2007, 09:46 AM
Shop Owner
nnick's Avatar
That's odd, I tried the 28 with yellow insert on ride wheels and they lasted 5 runs without any issues on lap times with some wear on them. Another 5 runs wear was obvious and lap times increased.
Overall satisfied, tood bad they don't have temp markings so we could use them on our championship
Nick
nnick is offline
Old 02-04-2007, 10:13 AM
Trader Rating: 39 (100%+)
I know Josh Numan ran a set for 2 race days and practice.. High bite asphalt. I like the much more tires for out door.
King of B Main is offline
Old 02-04-2007, 02:15 PM
drew85's Avatar
the tires worked great outdoor at Tamiya, med bite tracks about 90deg.
drew85 is offline
Old 02-04-2007, 02:35 PM
pit forgot to mention that we are using the premounted much more tires.
Turtlemaster is offline
Old 02-04-2007, 02:41 PM
thats what Josh ran
Old 02-04-2007, 03:20 PM
PitCrew's Avatar
Yeah, these were the pre-mounted tires.
You know, I didn't check to see if they had holes in the wheels.
I did say they worked really really good the first couple runs, then went to crap right?
PitCrew is offline
Old 02-04-2007, 03:27 PM
STARSCREAM's Avatar
maybe its just the characteristics of SIR....high grip so lotsa heat in them...
CJ, maybe try only buggy grip and warming next set...
STARSCREAM is offline
Old 02-04-2007, 04:27 PM
PitCrew's Avatar
Good idea.
I'll give them another shot. Infact I plan on using them pretty much exclusively from now on. I just don't want to have to buy a set every race day. But I will if I have to. Cause they are the shiznit
PitCrew is offline
Old 02-04-2007, 06:30 PM
wes
wes's Avatar
cj just my idea but i dont recall anthony ever using tire warmers and he is using only paragon addative. the regular wintergreen kind. i think he said hes getting something like 5 hot runs with them and then switches them out or soemthing. just what i saw.
wes is offline
Old 02-04-2007, 07:10 PM
PitCrew's Avatar
I tried the Paragon. I thought it sucked.
Tweak was way better.
5 runs make them a one night tire. Was hoping for more life out of them than that.
PitCrew is offline
Old 02-04-2007, 07:32 PM
wes
wes's Avatar
one thing i know for sure people are doing is when using the tire sander when you go to sand the bead off the center of the tire if you only do that the tire will not last as long and will be harder to make it work. this is directly from anthony too. instead sand the whole footprint of the tire and it will last longer and maybe hookup easier.
if you keep having problems just ask him.
wes is offline
Old 02-04-2007, 08:22 PM
PitCrew's Avatar
Uh, since when is Anthony the master of all knowledge?
I was running TC before he even had the idea.
PitCrew is offline
Old 02-04-2007, 08:23 PM
wes
wes's Avatar
well your having issues with it and he is not? but ok ill stop offering help then.
wes is offline
