Old 03-13-2003, 07:24 PM   #1
Default Battery matching & assembling
I've never assembled a mixed batch of cells. I was hoping someone could help me out here. I have about 60cells all zapped, cycled & labeled. Which numbers do I use to group them into 6cell packs? Do I go by mah, voltage, runtime or what?? Then, which numbers go on the outside of the pack? The higher or the lower? Thank you in advance for your reply=)
lameposeur is offline   Reply With Quote
Old 03-13-2003, 07:26 PM   #2
Forgot to mention, these are nimh.
Old 03-13-2003, 07:53 PM   #3
Hey lameposeur
It depends on what your looking for... I go first by voltage, then runtime, then IR... But I'm NO EXPERT just an average kinda guy that can't drive...
Have Fun!!!
Bradley J. Gotori
[email protected]
bgotori is offline   Reply With Quote
Old 03-13-2003, 10:32 PM   #4
dtm
dtm's Avatar
Send a message via ICQ to dtm
Here is what CE recommends.
For stock:
Runtime, Voltage, IR
For modified:
Runtime, IR, Voltage
In that order! If you have all your numbers in a Microsoft Excel file...it is a breeze!
dtm is offline   Reply With Quote
Old 03-14-2003, 12:48 AM   #5
Thank you guys for the reply. Do I put the larger number cells toward the outside of the battery or the inside of the battery??
Old 03-14-2003, 01:47 AM   #6
Send a message via AIM to RideRed98
i dont think it matter there are all paralleled...someone else give the right answer if this is the wrong one
RideRed98 is offline   Reply With Quote
Old 03-14-2003, 01:54 AM   #7
Herminator's Avatar
Send a message via ICQ to Herminator
well I do know they aren't connected in parralel, the cells are in series.
Herminator is offline   Reply With Quote
Old 03-14-2003, 10:31 AM   #8
You should put the higher number at the negative side and work towards the Positive. (Voltage, IR, and Run time. In that order).
That will give you more Punch. Don't worry to much about runtime.
milf is offline   Reply With Quote
Assembling Battery Packs Cubic$Racing Electric On-Road 4 06-12-2008 06:20 PM
Battery re-matching CORALLY NUT Rookie Zone 2 03-07-2005 04:36 AM
Battery Matching killerjvf Electric On-Road 7 01-31-2005 10:32 PM
battery matching HK Racing Joe Electric On-Road 1 10-31-2004 08:15 PM
battery matching gspot69d Electric On-Road 9 10-13-2004 04:26 PM
