Old 02-01-2007, 05:17 PM   #1
Default LIPO Balancers , write your knowledge here !
hi , i want to get a full lipo set up ,i already have an ICE and CELL MASTER chargers that use for my NIMH packs, so im going for maxamps 2S2P 8000 mah batteries , novak voltage cut off, but have almost no idea about balancers, how they work , what diferent types are , conectors ...
i heard that they are ones to connect as interface during charge and i gues what they do is to stop charguing a cell when it is completly full, so the other cell with continue charging till end
then there are others working after charge, so i gues they take some amps of the most loaded cell till voltages are exactly the same
is that right? , which one should i get?
i also read somewhere that packs conected in Paralell works like a single cell: they balance themselves automatically , so to balance a 2S2P pack you just need to do like in a 2S pack , is this correct?
im sure i am missing some important stuff so please let me know what you know
DrKucho is offline   Reply With Quote
Old 02-01-2007, 05:37 PM   #2
adamge's Avatar
If you really want to learn, you'll end up at rcgroups.com 's Batteries & Chargers forum.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 02-01-2007, 07:58 PM   #3
Trader Rating: 54 (100%+)
The equinox is one of the balancers that will balance the battery during the charge. Basically it charges up to lowest cell then maintains the balance through the charge. Also, with the optional high power connector set it can handle a charge at up to 6amps.
http://www.electrifly.com/chargers/gpmm3160.html
jsmax is offline   Reply With Quote
Old 02-01-2007, 08:11 PM   #4
padailey's Avatar
Basically you are correct about balancers... most you can either "charge" balance, which brings the lower cell equal to the higher cell while charging or "discharge" balance which brings the upper cell down to the lower cell. With the size of battery you are getting you will be charging at 8 amps (1C) so normally in that case with a lot of balancers you will need a some special wires to hook up to balance charge at that rate. My advice as far as balancers is don't spend a ton of money on a balancer. Just get one to do a balance discharge. As you read around you will find that guy rarely need them because their packs are rarely if ever out of balance. I ran my MaxAmps 6000 for about 6 months before myself and 3 other racers split the cost of a balancer. We all plugged in the balancer and not a single pack was out of balance. Pretty cool. Be careful of the taps though.. make sure you get a balancer that matches the tap on the battery.
As far as the parallel question you are correct. A 2S and a 2S2P both work as if there is only 2 cells. In the case of a 2S there is only 2 cells where there are 4 in a 2S2P but it acts like 2.
I haven't looked at the forum adamge mentioned (I'll have to check it out) but I do know if you look here at the Orion platinum threads there is a lot of info there. Or just ask away here and I'm sure someone will answer.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 02-01-2007, 08:17 PM   #5
padailey's Avatar
Also since you are thinking about MaxAmps here's a thread. http://www.rctech.net/forum/showthre...hlight=maxamps There's been a little talk about balancers and I think maxamps was going to start monitoring the thread if there were questions.
Tamiya TRF416X
Old 02-01-2007, 10:29 PM   #6
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Padaily. Any recommendations on a charger with the balancer built in?
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 02-02-2007, 05:13 AM   #7
thanks guys i will keep an eye on maxamps thread and rcgroups forum
Old 02-02-2007, 06:03 AM   #8
well thanks to adamge , i found this awesome article about balancing
http://www.rcgroups.com/forums/showthread.php?t=599287
everyone interested in balancing should read this
Old 02-02-2007, 07:21 AM   #9
MK_Arbiter's Avatar
does anyone use the high power plugs for the equinox?
MK_Arbiter is offline   Reply With Quote
Old 02-02-2007, 10:37 AM   #10
padailey's Avatar
Sorry I don't. I have an ICE and it charges awesome so I haven't looked for one. Best bet for finding one is to look at chargers geared towards the flight crowd. I may get another charger (Triton Jr or Orions Advance Flight Charger) for a backup for when I run multiple classes. My packs have NEVER been out of balance so I personally will not look for a charger with a balancing feature since I have a balancer which sits in a box. Once a month I plug it in and the green light comes on and it says its balanced. Back in the box it goes till next month.
Tamiya TRF416X
Old 02-02-2007, 11:00 AM   #11
adamge's Avatar
Here's another article:
http://www.rctoys.com/pr/2006/12/21/...-balance-tips/
and I wrote it ;>
-Nietzsche
Old 02-02-2007, 11:13 AM   #12
padailey's Avatar
Probably a good idea to balance every time. Geez it only takes a sec to check it out. I'll have to start doing that.
Tamiya TRF416X
Old 02-02-2007, 02:00 PM   #13
MK_Arbiter's Avatar
What's better balancing fater charging, or using the balancer in interface mode?
Old 02-02-2007, 02:05 PM   #14
MrBlack's Avatar
Here an explanation on how our balancer works at the bottom of the page:
http://www.teamorion-avionics.com/Ce...lancing+System
Also here is a diagram how to wire it when using high capcity cells (3000mAh+)
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 02-02-2007, 02:27 PM   #15
MK_Arbiter's Avatar
The orion balancer looks a lot like the electrifly. is the wiring for it the same?
HYPERION 1210i LIPO 2C CHARGERS AND BALANCERS Jwag R/C Items: For Sale/Trade 1 12-15-2007 07:45 AM
Wheel Balancers _pilot_ Electric On-Road 3 06-07-2007 06:10 AM
Hi to all Readers, wondering what to write in my first message NickolasVanily Florida Racing 0 12-31-2006 08:46 PM
12 Dec Straits Time RC Write-up rc-action.com Singapore R/C Racers 4 12-28-2004 02:30 AM
Edmonton magazine write up shortygy Canadian R/C Scene 2 12-23-2004 02:18 AM
