Old 01-30-2007, 04:58 AM   #1
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Spool on carpet w/rubber
Anyone tried this combo? If so what changes to the setup had to be made to get it to work (steer). Right now I am going with a oneway for the Birds but would like the consistancy of the diff with the drive off the corners of the oneway : thus the spool just don't know if it will turn.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 01-30-2007, 05:08 AM   #2
jo90's Avatar
I use a spool on carpet with rubbers here in the UK. Running the Mi2EC without turn in issues using LRP Vtec 24R's . The car is setup with 35wt oil all round, 5mm ride front with 25.5mm droop front (measured flat surface to top of thread on axle), 4 degree caster - 1 deg toe out. Rear is 5.5mm, 24.5mm droop and 2 degree toe in.
Car actually can oversteer easilly, I ususualy only run half the front (inner) covered in Corally TC4, full rears. My EC setup can be found on www.rcracechat.com
Hope that helps you
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 01-30-2007, 06:10 AM   #3
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Rod- I know that Juho ran a spool at last years DHI with a TC4, so yes, it's been done. I guess all you can do is try it in a practice round . See you SC boys down there.
Brandon Melton is offline   Reply With Quote
Old 01-30-2007, 06:29 AM   #4
Send a message via AIM to R/C Anonymous
I used to run a spool in the JRXS on carpet with rubber tires. Worked great and was fast but it took awhile to get it there.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-30-2007, 06:34 AM   #5
John Tag's Avatar
Trader Rating: 42 (100%+)
1 way or I lead the way.....
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-30-2007, 07:32 AM   #6
speedxl's Avatar
R/C Tech Charter Subscriber
Rod
We run spool on carpet with rubber tires. Spool allows you to dive and slide up under people when passing. Oneway is fast but you must be very smooth to be consistant.
Plus its a week away your way behind if you dont know which to run.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 01-30-2007, 07:45 AM   #7
AdrianM's Avatar
Carpet rubber is going the the same way asphalt is going. Drivers are working on setups and are finding spools can be faster. You may be able to get a few fast laps with a one way but you can get overall faster runs with a spool and the right setup.
Just like on asphalt you can drive harder into corners and use brakes.
Adrian Martinez
Old 01-30-2007, 07:46 AM   #8
A spool car won't win at the birds. Good luck Tony, Wally and Jason.
Juan Aveytia is offline   Reply With Quote
Old 01-30-2007, 07:49 AM   #9
Haven't been to to many tracks where I needed breakes for stock or 19 turn.
Old 01-30-2007, 07:49 AM   #10
John Tag's Avatar
I can say this.. I have a 1 way way and I drive in real deep with drag brake and at times use foward break in trigger and car is planted...Thats just me I drive it like I stole it..LOL
Like most said set up to your car and driving is key...
Hector.. be sure and stop by and say hello....
Old 01-30-2007, 08:27 AM   #11
RKeasler's Avatar
Actually I am not behind because it is oneway right now but no matter what if there is a better way I want to explore it. Week or not nothing matters til you get to the actual track you will be racing on. I may like the spool better.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 01-30-2007, 10:14 AM   #12
Yeti35's Avatar
I run a spool with rubber on carpet and love it. It is the same setup I use outdoors as well. People ask to drive my car and have a hard time with it for they don't know how to drive with a spool. Most here use diffs and occasionally a oneway but just diffs.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 01-30-2007, 10:21 AM   #13
UN4RACING's Avatar
Trader Rating: 22 (100%+)
In a previous thread a fella that sounded pretty up on spools posted be advised with a spool you are more likely to break an out drive or bend a dogbone if you hit some thing. And he did mention your more likely to increase lap times with the spool. I think its more for mod racing.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 01-30-2007, 10:38 AM   #14
stephen hilton's Avatar
i have been using a spool and a diff with good results. i went to a oneway and i found its by far the easiest to drive and i am more consistant and faster per lap any one know why?
stephen hilton is offline   Reply With Quote
Old 01-30-2007, 11:04 AM   #15
One ways IMO as just as easy to drive as dual diffs. Just gotta change the setup to accomodate it.
Geoff C.
JRXS Type R - rubber ready w one way+spool olhipster1 R/C Items: For Sale/Trade 13 02-12-2008 12:56 PM
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Problem with rubber on carpet Xrayskid Electric On-Road 6 10-26-2006 06:18 AM
Rubber on Carpet? edseb Electric On-Road 2 05-08-2005 03:43 PM
Rubber tires on carpet? TC3er Electric On-Road 22 03-10-2004 09:06 PM
