-   -   wall chargers for AA nimhs (https://www.rctech.net/forum/electric-road/147114-wall-chargers-aa-nimhs.html)
BillyCaldwell 01-29-2007 09:59 PM
What specs would I need in a wall charger for charging gp2300mah AA's?
Ive got an old jr ni-cdcharger its:
11.6v 50ma on the Tx output
Is that safe to use on AA nimh's?
Thanks in advance.
Marcos.J 01-29-2007 10:05 PM
Thanks in advance.
if is nicad only i wouldnt use it,
i use my Pulsar 2 and hook it up to the radio and charge them at nomore than 1 amp
Centerline Racing 01-30-2007 06:47 AM
I have four brand new wall chargers that came with my batts, but I use my R/C chargers for AAs. Two are energizer fold-ups that charge 4 batts at a time in pairs @ 360 mAh and the other two are off brand charging 4 batts two at a time @ 200 mAh. ( They are all for sale!)
You want to look for a charger with DC output of probably 15% greater than the total volts of the batts in series you want to charge. (ex.: 1 batt = 1.2v*15% charge @1.38v, 8 batts = 9.6v*15%, charge @ 10.93v) You can round up the voltage without any trouble.
Generally, all the instructions I've read state that you should charge at a rate no more than 1-1/2 times the rating. 1200 mAh = 1.2A. Charge no more than 1.2v*1.5 = 1.8v, rounded up: 2 volts.
My .02
Allan
