Old 01-29-2007, 10:33 PM   #1
akuhon's Avatar
Default muchmore motor fan posts
What fan fit MM fan posts. 25x25mm or 30x30mm ?
I'm using regular motors : Yokomo stock 23T and old Reedy KR
akuhon is offline   Reply With Quote
Old 01-29-2007, 10:52 PM   #2
WheelNut's Avatar
Send a message via MSN to WheelNut
Novak 5647 is what you need. 25x25x10mm.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 01-30-2007, 12:47 AM   #3
akuhon's Avatar
Thanks,
So I can mount this one on it.
http://www.delta.com.tw/product/cp/d...25x25x10mm.pdf
scroll down and see the spec for : AFB02505HHA
It's 5V. I think it's better because it has more amp than muchmore (MM only 0.05A , while this one is 0.16A and the new one is 0.24A). But also cheaper than MM ( see on RCmart for MM and on this site for Delta 25x25 fan)
So MM fan is too expensive and not so powerful to blow air for the mod. motor
Any better fan than this delta fan ?....
Old 01-30-2007, 01:01 AM   #4
WheelNut's Avatar
I can't say, no expirence. Although that Delta fan does look exactally the same as the novak in every way. All the 10mm tall fans will push a pretty similar amount of air. If it draws more amps it might push more air, since I suppose there must be more load on it, and thus it must be moving more air.
•Brad Comis
Old 01-30-2007, 01:23 AM   #5
akuhon's Avatar
Originally Posted by WheelNut
.......If it draws more amps it might push more air, since I suppose there must be more load on it, and thus it must be moving more air.
That's exactly my point ... more amp more air but lot cheaper in price. While for load issue ... The amp won;t dump the batts so fast (IMO)....
F/S Muchmore Motor Master Kevin K R/C Items: For Sale/Trade 0 05-16-2008 11:37 AM
MuchMore Motor Cooler + Orion Motor Performance Monitor mugengreg Australia For Sale/Trade 11 01-05-2008 09:56 PM
muchmore motor lathe New optionalhopup R/C Items: For Sale/Trade 1 03-17-2007 01:23 PM
FS: MuchMore Motor Cooler xxx787 R/C Items: For Sale/Trade 5 12-03-2006 01:06 PM
FS: MUCHMORE MOTOR MASTER V3.0C JoeyE R/C Items: For Sale/Trade 4 11-03-2006 10:48 PM
