Old 01-27-2007, 02:13 PM   #1
Default Motor wont work!!
Ok, well i havent been able tyo run my Ta05 recently becuase i stripped out a diff bolt, and im waiting for it to arrive. In the meantime ive installed some hop-ups. Ive got a futaba 3PKS, and ive been told that you can switch the crystals inside the modules, and ive done it many times before with other cars (they were all nitros), and ive never had any problems. I tired doing it with my TA05. it uses a synth crystal, so i just changed the channel it was on by turning the dials, and i installed a crystal in the 3PKS module. I turned it all on, and the steering worked fine, but theres a problem with my motor.Its a trinity Co27 PRO 27T motor, and its only been ran around 12 packs, so its still very new. When i pull the trigger the motorwill run for a second or 2, but very slowly, and then it will slow down to a stop, and the motor wont turn. Every time i unplug my battery and plug it in again the same thing happens, it will run for like 2 seconds, and then sto[ working. When i pull the trigger and it doesnt move i hear a beeping/buzzing noise. Currently the motor is disconnected from the drivetrain, so i know that isnt my problem. Any ideas on what wrong??
P.S. My ESC is also brand new, a Novak XRS ESC.
rs43evoman is offline   Reply With Quote
Old 01-27-2007, 02:32 PM   #2
MK_Arbiter's Avatar
Is your battery charged?
MK_Arbiter is offline   Reply With Quote
Old 01-27-2007, 02:42 PM   #3
RandyB's Avatar
check the brushes in the motor. they may be just hung up. If you dont know what they are, its the braided wire coming out of the motor. Pull on them and let them snap back as they are on spring tension.
RandyB is offline   Reply With Quote
Old 01-27-2007, 03:07 PM   #4
Iceracer's Avatar
Try hooking the detached motor directly up to a battery pack and see how it runs. If it runs as it should, then suspect the ESC or the setup with the transmitter / receiver. Are you sure you have the receiver and ESC set up correctly? Is there an indicator light on the esc to show when you have brake postion, neutral and full throttle activated? Maybe its not set up right.
Iceracer is offline   Reply With Quote
Old 01-27-2007, 03:20 PM   #5
It must have been either the pack , used a differnt one and it worked fine.
Old 02-04-2007, 02:42 PM   #6
Ok guys the battery didnt fix the problem. I know the batery im using was fully charged, i went out and ran the car for about 30 secs (for those 30secs, it was perfect!!!!, first time running it with all the hop-ups, and the locked rear diff), and it all of a sudden stopeed working, the lights on the esc were funcition correctly, i went to look at the brushes, and i think I broke one of my springs becuase its a little bit shorter then the other one now, and it mount fit. Im gonna order some new brushes, and srping, but the current ones look perfectly fine, except both of them have small nics in one of the edges. Could that be my problem??
Old 02-05-2007, 04:56 AM   #7
any1??
Old 02-05-2007, 05:01 AM   #8
PerformanceRC's Avatar
Can u take a photo?
PerformanceRC is offline   Reply With Quote
Old 02-05-2007, 05:03 AM   #9
tc3team's Avatar
Have you got another motor you know that works ok to try it with?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-05-2007, 05:12 AM   #10
sosidge's Avatar
Sticky brush.
Try cleaning the motor with motor spray and a comm-stick/cotton bud (take the brushes out and clean the contact faces).
If that doesn't work you need a total rebuild - comm skimmed and new brushes.
Old 02-06-2007, 04:59 AM   #11
Will a comm stick keep my time between comm cuts longer? IM just bashing, not seriosuyl racing so i rarely cut the comm?
IS this my best choice for a comm stickComm Stick
Old 02-06-2007, 07:39 AM   #12
get a fibreglass pen, and clean the sides of the brushes as well. this will improve conductivity from the hood to the brush as well. and remove any debris that may be making the brush stick. you can use this to clean the face of the brush too, and the comm as well, if its not scored deeply, and you don't have a lathe.
3M makes it, called a rust remover pen, it looks something like this:
http://www.sjdiscounttools.com/abras...nding-pen.html
its one of those tools to have in every pit box if you run electric.
MManson is offline   Reply With Quote
Old 02-08-2007, 05:10 AM   #13
Ok, ill gert one of thos, seems like a simple, but smart idea
Old 02-10-2007, 12:50 AM   #14
AzBobby's Avatar
you said you have been running nitro's right. well in nitro's your throttle in the reverse mode in your controller, and if your running a high end race esc it only has forward and brake. may want to check that. also crystals can becomes damaged roaming around your tool box very easily. if you dan't have a crystal case then see if someone you race with has a set you can try and see if that helps.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-10-2007, 10:45 AM   #15
GreaseMonkey's Avatar
Have you tried reprogramming your ESC to the transmitter?
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
testing a electronic speed control wont work auctioneeral Radio and Electronics 2 03-23-2012 05:01 PM
marder wont work :weird: tomw07 Monster Trucks 9 01-27-2008 12:37 PM
marder wont work tomw07 Nitro Off-Road 3 01-26-2008 04:09 PM
losi mini t steering wont work sparkplug1288j Micro and Mini Scales 4 12-01-2007 01:18 AM
E-Maxx got wet not it wont work! Lethal™ Rookie Zone 12 06-30-2007 01:19 PM
