How do you get the perfect finnish on your chassis >
Old 01-26-2007, 06:35 AM
Wing Chun's Avatar
Default How do you get the perfect finnish on your chassis
Hi Guy's
How do you guy's get the best finnish on your edges of you carbon fibre chassis, battery holder's edges, Common tell us your secret's to getting the best finnishes available.
What glues and tools do you use.
Thanks Guy's
Addam
Wing Chun is offline
Old 01-26-2007, 06:41 AM
John Tag's Avatar
Trader Rating: 42 (100%+)
After sanding smooth some are using Black sharpies then a layer on CA glue applied by Q tip real easy and smooth strokes.. Hope this helps..
John Tag is offline
Old 01-26-2007, 06:50 AM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
ZAP C/A And a Black sharpie.
UN4RACING is offline
Old 01-26-2007, 06:52 AM
imprsme's Avatar
Trader Rating: 82 (99%+)
The clean looking chassis I have seen are not even glued! They were wet sanded to perfection!!!!!
imprsme is offline
Old 01-26-2007, 07:03 AM
heretic's Avatar
www.overrc.com, go to " Préparation de châssis
et autres pièces en fibres de carbone."
heretic is offline
Old 01-26-2007, 08:48 AM
AssocRacer's Avatar
you can wet sand the carbon fiber all you want to make it look pretty, but we all know that carbon fiber's weak spots are the edges, so you need to seal them with CA glue. I like the idea of using the sharpie, then brushing the CA on with a cue tip, works awesume. That's what i did on my TC4
AssocRacer is offline
Old 01-26-2007, 08:52 AM
Get some that know how to do for you. That I had do as I could not sand mine in my house do to newborn and the dust.
cyrrus is offline
Old 01-26-2007, 09:34 AM
AM03GT's Avatar
is it really worth the effort to do it "perfectly"? after you build the car you can hardly tell how well its done... i spent a few hours on the chassis on my Reedy Race car, top deck shock towers... everything... wasn't worth the time lol. now i just do enough to protect the chassis
quick wet sand of the edges, a slight bevel for the batteries, then a quick CA with q-tips...
AM03GT is offline
Old 01-26-2007, 10:02 AM
Yeti35's Avatar
I did not think you were supposed to seal the edges on anything but the bottom chassis. I never do anything else but the bottom deck for I was told if you did the other stuff you could experience a tweak issue.
Yeti35 is offline
Old 01-26-2007, 10:14 AM
Chemical X's Avatar
Trader Rating: 17 (100%+)
What's the purpose of using a black Sharpie when finishing the chassis edges? I'm assuming it's just cosmetic.
Chemical X is offline
Jack Smash's Avatar
Trader Rating: 33 (100%+)
IMO, a well sanded chassis w/o CA is much less likely to delaminate than an average sanded one w/ CA. I don't believe a thin layer of a brittle glue is going to do much to keep the chassis from splitting, I have never had a chassis that I have sanded spilt, ever.
Jack Smash is offline
Old 01-26-2007, 10:26 AM
J C F D's Avatar
Yes.
I sand then use a silicone that I put into a empty CA bottle. Then use that. I just built my JRX-s in the winter so I havn't used it that much.
But my LHS owner had the xray and he didnt seal his and he ran with our 1/10th scale onroad sedans and got T-bones buy a serpent 720 . Nothing happened except a bent real hinge pin or axle not sure its been so long.
SO all in all I think its up to the builder if they want to use these tips. I know it hasnt hurt mine so far.
J C F D is offline
Old 01-26-2007, 10:53 AM
Get yourself a Tamiya Hard Coated File, it will make your life easier when you file the battery slot.
trf_racer is offline
Old 01-26-2007, 12:32 PM
mxracer23's Avatar
CRC has a really good guide here is a link
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
mxracer23 is offline
Old 01-26-2007, 02:07 PM
Wing Chun's Avatar
Thank's Guy's
Some really great info there. I have 2 MSX and one of them was already done because it was second hand and that job was so good and smooth. The other MSX was new, so when I did it I used cheap super glue and it came out crap, So now I will use your tip's to get a great finnish.
Thanks Guy's
Addam
