Let me pick your brain ex-tc3ers >
Old 01-25-2007, 12:40 AM
seems like everyone is an ex tc3 driver so I am asking you for help.
I bought two tc3s from a buddy and I have heard of a ntc3 steering mod I want to know how to do this. Is there really any benefit? Is it just bolt on with some grinding or are there new holes to be drilled? or can I use tc4 steering? I know what you are thinking, buy a new car, well i am kind of waiting for tc5 so if i could get some help for now it would be greatly appriciated.
ruinn is offline
Old 01-25-2007, 06:13 AM
http://tpjexelby.tripod.com/NitroRackPics.htm
Tim shows you the right way to install the nitro tc3 steering rack into a tc3.
LJae is offline
Old 01-25-2007, 07:41 AM
Dane's Avatar
Trader Rating: 25 (100%+)
If you want consistent steering angles, I heard this mod doesn't get the job done. If I were you, stick with the rack, keep it clean including the bushings, and wait ever so patiently until the TC5 comes out within the next 10 years
Dane is offline
Old 01-25-2007, 07:46 AM
Agreed... with the exception of waiting for the TC5
MManson is offline
Old 01-25-2007, 09:16 AM
AM03GT's Avatar
if you're going to drill the chassis to mod the steerin you might as well get the TC4 steering rack which is based off the NTC3...
AM03GT is offline
Old 01-25-2007, 09:23 AM
AssocRacer's Avatar
Just an FYI, the TC3 is still a bad ass car, in fact, there were two or three in the A-main at the Novak race.
AssocRacer is offline
Old 01-25-2007, 09:36 AM
Jack Smash's Avatar
Trader Rating: 33 (100%+)
The TC3 steering rack is one of the reasons that car was so good and why the TC4 had a horrible push IMO.
Like Dane said, Keep it clean and adjusted properly and it is great. Use the stock bushings, don't use bearings. For some reason the bearings cause the rack to bind.
Jack Smash is offline
Old 01-25-2007, 11:07 AM
JL
If you look on the associated website there's a template for a steering rack cover that you can make with scrap lexan from bodyshells.
JL is offline
Old 01-25-2007, 11:28 AM
sweet thanks guys the info is great keep whatever GOOD mod ideas you have coming. Oh and the car is bad ass, no doubt. The steering just felt a litte sloppy and the tc4 felt nice and tight. But from you guys sound like it just needs some maintence. Thanks again and any further info will be appriciated.
ruinn is offline
Old 01-25-2007, 11:59 AM
Sam_Smith's Avatar
Shimming the diffs correctly (maybe taking a bit out of the inside of the diff housing where the bearings sit) and changing the front shock tower to a rear shock tower makes the best improvement IMO on the tc3
If the guy you got it off ran the car though he will of most probably already done the things above as I think most did
Sam_Smith is offline
Old 01-25-2007, 12:12 PM
Dane's Avatar
Besides keeping everything clean and in good repair, check out an article that RCCA did a couple years back in the Special Touring Edition issue. It lays out pretty well how to "blueprint" the TC3 transmission. It's probably the best thing I've done to the car.
Also, if you have rubber seals on the bearings, remove at least one side to free your transmission further. This might be stated in the article mentioned above.
Freeing up the transmission and keeping everything maintained is the best way to improve your TC3.
Hope this help and enjoy.
Dane is offline
Old 01-25-2007, 12:26 PM
nope tc3 is bone stock i went to local track and got some idea the rear shock tower on and the two hole front a arms. Aslo someone mentioned using losi hub carriers for durability.
ruinn is offline
Old 01-25-2007, 12:40 PM
Dane's Avatar
Originally Posted by ruinn
nope tc3 is bone stock i went to local track and got some idea the rear shock tower on and the two hole front a arms. also someone mentioned using losi hub carriers for durability.
Yeah you can use them although I never saw a need for them running the TC3 for 4 years.
I bet you'll be coming back for setup help so I'll give you an answer now - check out www.rc10.com where team drivers have posted their setups based on surface and other parameters. Start there.
Dane is offline
