Old 03-10-2003, 03:25 PM   #1
Send a message via Yahoo to dstrout
Default Should I use offset rear hubs (losi)?
I've got an XXX-s that was upgraded to graphite by a former owner. Well, this past weekend, I managed to break a rear suspension arm, and I noticed that the replacement had two holes for mounting the hub. I didn't think much of it at the time, but then noticed today that the other (non-broken) are doesn't have that. Then I got looking at the Losi site & saw the page about the offset rear hubs, and the picture showed them mounted in the inner of the two holes.
I have a set of A-9854 Graphite offset rear hubs in the pile of spares that came with the car. I run foam tires on an indoor track with new very grippy carpet, and we have one long straight, the rest is pretty twisty. The car has a front one way and a GM2 motor.
Should I install the offset hubs, and what advantage do they convey?
thanks,
dave.
dstrout is offline   Reply With Quote
Old 03-10-2003, 10:24 PM   #2
Korey Harbke's Avatar
The offset hubs will let the car rotate better through the corners. They are generally used for small tracks. If you use the reg hubs it will feel more stable and better for big tracks.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-11-2003, 05:37 AM   #3
Send a message via AIM to RideRed98
i have the graphite plus and i have noticed just the opposite with the offset hubs in my situation.....with the older hubs the cars back end is just slightly looser resulting in quicker rear-end rotation...i personally use the older NON offset hubs cause of my situation
Geoff
RideRed98 is offline   Reply With Quote
Old 03-11-2003, 06:16 AM   #4
Cole Trickle's Avatar
On my Pro2 a 3 mm off-set in the rear, results in a little better turn-in. But I didnt notice any unstability at all.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-11-2003, 06:26 AM   #5
Default Well what is it / how does it work?
Well, let me ask this -- in what way is it offset? Are they wider? Or do they have more camber? In other words, in what axis is the offset? Any ideas how it works to make the turn in faster?
thanks,
dave.
Old 03-11-2003, 06:55 AM   #6
Off-set in this case, means wider. Why it works? I dont know. But to me the advantage was so little, that I've ditched it.
Old 03-11-2003, 07:02 AM   #7
Default Hmmmm...
Hmmmm -- I may have to throw them on and see. I've got a set of corolly tires that I bought by mistake that are slightly wider than the Jaco's, such that they rub on my chassis. 3mm would probably be enough to let them fit, and more rubber (foam) on the ground is always a Goot Thing...
thanks,
dave.
Old 03-11-2003, 07:44 AM   #8
Yes, but then you dont know what is what.... the handling change you'll gain, how much of of it came from wider tires and how much came from a wider rear....
For experiment, use a spacer instead. Between the hex hub and the rim. HPI rims comes with these spacers as standard. Just remember that with standard wheel nuts, the nylon lock wont work.
Old 03-11-2003, 08:09 AM   #9
Default My rear gets wider every year...
True. The right way to do it would be to put the offsets on, try it, then put the corollys on, and compare.
Since I'm running a one way (not by choice -- I'm missing the parts to put together the front diff ), I need as much stability in the rear as I can get. I'll have to experiment with the offsets & different tires when I get a second.
thanks to all!
dave.
Old 03-11-2003, 08:35 AM   #10
Rear stability? In which situations?
A couple of tips, that might help on the one-way situation (dont know if you know them, tough...)
Stability:
Extra front toe-in. At least one degree total.
Reduce front downtravel to around 1 mm.
If possible, add in ekstra castor.
General:
If possible. disable auto-brake on the ESC.
Alternatively, adjust the TX throttle trim, so the car crawls a little, when throttle are at neutral.
Depending on situation, you might want to stiffen up the front / soften the rear.
Old 03-11-2003, 08:52 AM   #11
tufferwilde's Avatar
Cole Trickle - Actually, what you stated is incorrect. On the XXXS - the offset hubs simply move the lever point on the rear arms in while making the hub itself longer... this has absolutely zero to do with the actualy width of the cars as we are governed by the 190mm rule... Losi has made the parts to be as close to this width rule as possible.
In an answer to the original question - sushi boy answered it quite succinctlyin fact.. on the XXXS - the offset arms work far better to let the rear of the car rotate through the corner - but it will give the car an unstable "on the edge" feeling... this is also quite useful on carpet tracks where the traction is such that the looser rear end of the car will make for faster lap times.
I have run both styles of hubs on carpet and I find that while the car feels somewhat unstable, the fastest lap times are with the offset hubs... in mod, I was using the 0 degree, offset hubs, while in stock, I used the 1/2 degree mounted on the opposite sides to take away some rear toe... once again - carpet is a high enough traction surface
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 03-11-2003, 08:55 AM   #12
Cool, all advice is greatfully archived for reference!
As far as stability, I've got two issues -- one is that the car wonders a bit down the straight. I was going to add a bit more front toe-in to try & solve that, so we're on the same page there.
The other area is that it's easy to break the back end loose. I'll try dialing out some braking. Likewise on softening the rear -- I removed the rear sway bar, and I was planning on going softer in springs if that doesn't do it.
What I'm wondering is if the wider track / wider tires won't help at the same suspension settings. That way I don't have to worry about getting so soft that I start getting body roll / traction rolls.
thanks alot,
dave.
Old 03-11-2003, 11:54 AM   #13
dstrout -
Check out the setup that Hodge posted on the Losi site - it works very well!! I am using the Losi 30 lb springs in the rear and the 35's up front in my stock car...
As for the wandering on the straight - part of that could be the fact that you are using the oneway - on power, the one way tends to make the car a little bit touchy.... same with the spool.
In stock - I run a spool (at least I did the last time I raced the car.... and it was allright - pulled like crazy through the corners, but got sketchy on the straight sections - had to keep making steering adjustments
Regarding the foams - the best that I have found yet is the TRC black mesh Plaids up front and the purples in the rear - they seem to be a little bit more forgiving than the yellow rims are... I am going to try out a couple of Orion foams the next time I run too... You can get away with up to 28 mm width tires on the car, but you will have to widen the front to the max legal limit to run em... as they will rub on the shock ends.... the rears don't seem to have the same issues
Wilde
Old 03-11-2003, 12:31 PM   #14
Wilde
Okay - that's what comes out, when I comment a car I dont know - thanks for correcting me.
Old 03-11-2003, 12:37 PM   #15
I'll check it out -- I think I've got it printed out in my notebook, but I can't say that I studied it in great detail.
I didn't think about the one-way having an effect in the straights... That's exactly what I'm getting, though. It's trimmed ok, rolls straight at slow speeds, but WFO I have to work to keep it between the rails.
I just tore the front end down and cleaned / lubed everything, as one wheel wasn't as free as the other, so that may help too. I'll get it all back together and we'll see where it's at.
thanks to all!
dave.
Tyre Offset. Front and Rear. bin Electric On-Road 6 05-06-2008 09:58 AM
Losi XXX BK2 Front Aluminum pivot block/rear hubs rctazmanmc R/C Items: For Sale/Trade 8 04-05-2008 06:10 PM
Losi 8ight Trinity aluminum rear hubs Kane-o Nitro Off-Road 0 12-22-2007 10:42 PM
Losi JRX Rear Hubs & Sliders.. kevin107 R/C Items: Wanted to Buy 1 08-31-2007 09:15 PM
XXX-S non-offset rear carriers with black ball studs? dpaton Rookie Zone 0 10-22-2003 03:01 PM
