Ta05 Diff bolt
Old 01-21-2007, 02:53 PM
Default Ta05 Diff bolt
I'm in need of a diff bolt, and the 2mm nylon lock nut it threads into for a Tamiya Ta05. Ive looked at my LHS, my local hardware stores, and on-line, and i havent found anything. Its a 2x25mm bolt, and the nut is 2mm. In the tamiya manual it says they have the same part # so im assuming they come together in a bag. Could anyone provide me with a link to a site which sells the parts.
rs43evoman is offline
Old 01-21-2007, 04:25 PM
any1?
Old 01-21-2007, 04:45 PM
sportpak's Avatar
Trader Rating: 26 (100%+)
I believe the number is #9949350. This should be the bolt and nut in the same package. I am pretty sure of this. Check it on the tamiyausa website to verify.
sportpak is offline
Old 01-21-2007, 04:49 PM
TryHard's Avatar
I assume your in the US?
If so drop Steve at Speedtech RC a line, I'm sure he can get hold of one for you, even if it's not on his site.
HiH
Ed
TryHard is offline
Old 01-21-2007, 04:50 PM
sportpak's Avatar
http://www.tamiyausa.com/product/ite...uct-id=9949350
I just checked it out for you. There is no picture or real description. But it says 2 pcs. So this is the correct number. It is the bolt and nut.
sportpak is offline
Old 01-21-2007, 04:53 PM
TryHard's Avatar
thats correct... from an old RC Champ order of mine.
Regrading the 9949350, this is not 2mm lock nut, this is 2x25mm cap screw with 2mm lock nut.
HiH
Ed
TryHard is offline
Old 01-21-2007, 06:33 PM
sportpak's Avatar
I think that's the first time I got a number right on here..
sportpak is offline
Old 01-21-2007, 06:36 PM
thanks for the help guys, didnt see the ta05 thread, would have osted my question there.
Old 01-21-2007, 08:44 PM
Core Creations's Avatar
Trader Rating: 105 (100%+)
Actually it's 2 bolts...no nut.
Core Creations is offline
Old 01-21-2007, 10:31 PM
Slotmachine's Avatar
Go Here for 10 diff nuts in a bag............Part #TAM9805889
Slotmachine is offline
Old 01-22-2007, 05:01 AM
On rcmart.com they say its 2 peices, but in the picture it shows 2 bolts, and 2 nuts. Im gona send them a e-mail and figure it out. Also i couldnt find the part on any other site besides them, I know there based in hong kong, so does tamiya use different part numbers for its US division, and the other area it sells to??
Old 01-22-2007, 08:40 AM
sim600's Avatar
Trader Rating: 15 (100%+)
I also stripped my diff nut but the bolt was still good. I asked a guy who plays those Tamiya mini-4wd slot cars and he had like a ton of spares. Heheh.
sim600 is offline
Old 01-22-2007, 10:33 AM
In a pinch knock the center part out of the tamiya thrust bearing and use an associated TC3/4 nut and bolt.
GroffBall is offline
Old 01-26-2007, 03:34 PM
Ok guys, are there any US sites (that means not Rcmart.com) nthat has the diff bolt. Ive looked everywhere and the only place i can find is Rcmart, and i wanna get it soon.
Old 01-26-2007, 04:48 PM
sportpak's Avatar
www.tamiyausa.com
Search that part number, then order it. Piece of cake dude.
sportpak is offline
