Team ORION 4200 V-MAX PLUS RDS WC CELLS INFO >
Old 01-20-2007, 04:16 AM
Default Team ORION 4200 V-MAX PLUS RDS WC CELLS INFO
Whats the best charging methods for these cells baring in mind they are brand new?
Ive been told not to charge them at a very high ampage level when new.
What should i charge them at new at and re-peak them at?
What ampage and delta peak etc should i charge and peak at etc when theyve had afew charges etc?
I'm running in 27t stock class and using ctx muchmore discharger/discharger.
Also have the muchmore ctx-d2 personal discharger/personal matcher.
Anyone have a idea what values should be set on this for matching the cells?
finch is offline
Old 01-20-2007, 02:31 PM
stephen hilton's Avatar
charge them at 4 amp for the first 6 charges or so 3mv/cell and then step it up to 5 or 6 amp depending on how long you want em to last hth cya wednesday
stephen hilton is offline
Old 01-20-2007, 04:45 PM
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
I woud also like someone to shed some light on charging/trying for new IB4200WC's also.
BSchorr is offline
Old 01-20-2007, 05:26 PM
TLRacing
Todd Hodge's Avatar
I charge my packs at 6.0 amps with a .03mv cutoff with an Orion Advantage Charger. After my run, I will discharge the packs after a run down to 5.4v at 30amps to check runtimes. If I am going to run the pack the next day I will leave it alone. I will tray the battery in a much more tray before my next run. If not I will put atleast a 50% charge back into the pack. Then discharge it and tray the battery in a Much More Tray down to .9v per cell. Then charge for racing. If the pack peaks 5 minutes before I run I will not repeak. If it is longer I will repeak.
Todd Hodge is offline
Old 01-20-2007, 05:45 PM
BSchorr's Avatar
Hodge,
Do you use the temp probe at all that came with teh Orion Advantage Carbon charger? I have teh same charger, and was doing some testing with it. I foudn that the sensor was very un-accurate, and is not magnetised like the manual/website said it was. i have to use tape to keep it snug to the cell. I said F it and just use 3-4mv per cell cuttoff, so thats 18mv or 24mv cuttoff per pack. I know people that use GP 4300's, the have to set their mV higher because the makeup of the GP cell is alot differnt and takes a higher mV setting, like 30mV+ per pack.
As far as teh stupid temp probe goes, i set it to cuttoff at 52 Celcius, which is 125 degrees. i was monitoring it while charging, and the highest it got with a regular old 6 amp charge was 49 celcius, but the pack was like 135+ degrees! so i wont be using that prob anytme soon!?
BSchorr is offline
