Charging AA's with CDC v6b >
Old 01-19-2007, 06:04 PM
surrealmaterial's Avatar
Default Charging AA's with CDC v6b
Hey,
Has anyone ever charged transmitter batteries (AA's) with a CDC v6b? If so what rate do you charge at and what cutoff do you use?
Cheers,
Dave
surrealmaterial is offline
Old 01-19-2007, 06:23 PM
Trader Rating: 81 (100%+)
what is the capacity of your aa's? nicad or nimh?
this is for nimh: for 1800mah and below, i charge at 0.5 amps. it takes about a couple of hours to peak but i found that this rate doesnt heat up the batteries as much. for 2000mah and up, i charge at 1 amp. if the batts heat up too quickly, i drop the charge rate a bit. i use the lowest cutoff available for nimh, i think 2mv (or .2 ?? ) is the lowest for cdc. hope this helps
marvi is offline
Old 01-19-2007, 06:33 PM
thanks....i am using 2650mah AA nimh....can i put them all into a pack and charge them all together or do i have to charge 1 by 1? Also they are 1.2v, will this be enough to power my Futaba 2PL?
Old 01-19-2007, 06:49 PM
im not familiar with the 2PL. does it have a charging jack? if it does, try looking for a futaba jack that fits it and hook up the positive and negative leads to your charger. this way, you dont have to take out the batts everytime you charge.
if you dont have a charging jack, you can buy an 8 cell battery holder from radio shack or other electronics shops. put all your batts there, make sure the polarities are correct, then hook up the + and - to your charger
1.2V per cell is enough power for your radio 8 cells peak at 10+ volts total and stay above 9v for a long time this is ok for your radio
marvi is offline
Old 01-19-2007, 06:52 PM
ok cool thankyou
Old 01-19-2007, 07:33 PM
on my 2PL if i let the batteries go down to 8.5v (which is were the alarm sounds) will i loose control of my car?? or will it be fine for a few more minutes?
Old 01-19-2007, 07:36 PM
Casper's Avatar
Trader Rating: 34 (100%+)
Take the out of the radio. Charge them at .7amps with a 3mv/cell cuttoff. They will do just fine! You can go up to 1-1.5amps but the cells will get a little hotter when peaking. I would only use if you do not have time.
Casper is offline
Old 01-19-2007, 07:57 PM
CarlosG.'s Avatar
I have found out that charging them over .8 amps that they don't hold a charge long enough, but if you charge them at or below that rate they will last longer. They don't really like to be fast charged. I have the Energizer 2100mah AAs. The charger that it came with over heated them and did not hold a charge long enough.
CarlosG. is offline
Old 01-19-2007, 08:00 PM
well i got Duracell 2650mah and the recommended charge rate is .27amps over 16hrs......should i charge at a current below this?
Old 01-19-2007, 08:02 PM
Casper's Avatar
Charging at .5 will be safe. They tell you to slow charge them which is not bad advice but it will take forever!
Casper is offline
Old 01-19-2007, 11:10 PM
you wont lose control once the alarm sounds, but its better to bring the car in.
marvi is offline
Old 01-20-2007, 02:58 PM
i am in the process of charging them at the moment and they have reached 3800mah, and still going.......there supposed to be around 2650mah..........should i stop the charge or keep going? (they are only warm at the moment)
Old 01-20-2007, 03:46 PM
Casper's Avatar
I would pull them off. That is way too much for those batteries.
Casper is offline
ok
Old 01-21-2007, 02:05 PM
i just finished charging them all, they charged to 3800.......i put them in and they showed 11.2v. When there only supposed to be 1.2v ea x8=9.6.....
