Old 01-18-2007, 11:05 PM   #1
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Lightbulb Mounting a Fan
Hey Guys,
im in the process of trying to mount a small fan to blow air onto the endbell of the motor in my Xray FK'04.........any ideas???
thanks
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 01-18-2007, 11:55 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by surrealmaterial
Hey Guys,
thanks
try this
http://www2.towerhobbies.com/cgi-bin...p?&I=LXJKA9&P=
Old 01-19-2007, 12:03 AM   #3
I)arkness's Avatar
i believe you can buy certain parts to allow you to connect a fan facing the endbell of the motor i know much more has one, heres a pic its a bit small
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 01-19-2007, 12:26 AM   #4
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
http://nexusracing.net/product_info....8da07574f5b7ec
Just use that :P
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 01-19-2007, 12:53 AM   #5
Boosta's Avatar
try this fella really good fan setup you can run twin fans on the motor and there's an extension to run one on your speedo aswell cool can fans also if you go to the company disscussions board they have a thread on there where you can see feedback etc
Boosta is offline   Reply With Quote
Old 01-19-2007, 01:53 AM   #6
jo90's Avatar
Get the Much more endbell fan screws and then search the web for 30mm fans, alot cheaper than most of the options and alot more affective too !
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 01-19-2007, 01:55 AM   #7
Were would the screws go into on a 540 silver can motor?, which is what im running....
Castle Hill Raceway
Old 01-19-2007, 01:56 AM   #8
jo90's Avatar
you hadn't said that, in this case they will not fit at all. Buy a 40mm fan and strap it to your chassis.
Old 01-19-2007, 01:59 AM   #9
sorry, but thanks
Castle Hill Raceway
Old 01-19-2007, 02:01 AM   #10
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
the heatsinks for 540 motors might work... there's a version where the fan mount is offset to go above the endbell and not the can.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-19-2007, 02:43 AM   #11
have you got a internet site or a pic?
Castle Hill Raceway
Old 01-19-2007, 02:45 AM   #12
Hi jo90,
Can this be installed on the V2 motors? thanks in advance..
OrAnGe PoWeR is offline   Reply With Quote
Old 01-19-2007, 03:58 AM   #13
shift's Avatar
much more do another version just for v2 motors but i dont think they fit 30mm they are designed for a 25mm fan
shift is offline   Reply With Quote
Old 01-19-2007, 04:09 AM   #14
VooDooPH's Avatar
here's one from 3 racing. I'm using the same one but i chucked the stock fan out the window (they're crappy and can hardly blow any air). replaced it with a novak 30mm fan which recently broke in a crash. looking to get my hands on a MM 30mm fan to replace it.
come to think of it, why would you need a fan if you're running a stock johnson motor? if the motors coming off really hot i doubt a fan will help. might be better to check out your gearing and/or roll-out numbers.
Old 01-19-2007, 07:14 AM   #15
jo90's Avatar
I think they do, but as shift said I think they need the 25mm fan, much more do both but are pricey, that's why I got direct to the net and find some good Computer websites that stock board and cpu fans, they go from 17mm up to 30mm, from .7cm to 1cm thick. I opt for the 1cm thick so they can handle a whack from another car better.
Mounting a Mamba Max ERustler Electric Off-Road 9 09-12-2007 12:35 PM
Wing Mounting atxgman Electric On-Road 8 06-08-2007 06:47 AM
need pic with fan mounting pinggoy Electric On-Road 5 10-11-2006 11:57 AM
Receiver mounting? Racingfreak6 Electric On-Road 4 08-19-2006 07:19 PM
Fan mounting Mark G Electric On-Road 4 06-06-2006 12:41 PM
