Mounting a Fan
Old 01-19-2007, 01:50 PM
  #16
surrealmaterial's Avatar
Originally Posted by VooDooPH
come to think of it, why would you need a fan if you're running a stock johnson motor? if the motors coming off really hot i doubt a fan will help. might be better to check out your gearing and/or roll-out numbers.
the gearing im running is perfect for the track, so id prefer to keep that the way it is. Because when i come off the track my motor smells really bad, so ill give the fan a go and if it doesn't work ill take it off
surrealmaterial is offline
Old 01-19-2007, 02:03 PM
  #17
bxpitbull's Avatar
Default I use a heatsink w/fan
I use a heatsink w/fan that has the fan directly over the sink by 3racing. That puppy works like a dream. Running the 4.5, my motor has never seen a hair above 130 degrees. Running Li-Po, I have run 20 minute races with nitros and the motor never gave me a problem. I have tested it without the fan, and that was the only time the temps shot up to the 140's. By brushless standards, that is about average. So, I must give the big thumbs up to fans on the heatsink.
bxpitbull is offline
Old 01-19-2007, 02:04 PM
  #18
ok thanks....what brand and size fan are you running??
Old 01-19-2007, 05:40 PM
  #19
Birky's Avatar
I don't think you will be able to use a heatsink and fan on the FK04 because of the bulkhead running over the motor (there is no way of mounting the heatsink to the motor). This is why I upgraded my Evo2 to a FK05 because it gets extremely hot in summer where I race and there was no way (apart from mounting a fan direct to the chassis) to artificially cool the motor.
Birky is offline
Old 01-19-2007, 06:45 PM
  #20
killingtime's Avatar
I'm using this mount and am VERY pleased with it. It puts the one fan at an angle into the endbell/comm and the other pulling hot air out of the can.
Team Tamale , just click on "clamp on fan mount"
killingtime is offline
Old 01-19-2007, 06:54 PM
  #21
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Is anyone you know of stock this fan or did you order it directly from them? That looks really trick.
wyd is offline
Old 01-19-2007, 07:05 PM
  #22
I)arkness's Avatar
yeah i dont think your going to be able to mount a fan on the 540 motor with the fk04 unless you try and put some wholes on the endbell , then tap it which it might hold the fan on the end
that car is just like the tamiya ta04 there is no room at all except the endbell option
I)arkness is offline
Old 01-21-2007, 10:12 AM
  #23
Directly from Team Tamale. I don't think he can make them fast enough to try to stock another shop other than his own.
Old 01-21-2007, 11:08 AM
  #24
rc1racer's Avatar
Teamtamale used to make a mount for the FK04 that clamped to the bulkhead above the endbell and was angled toward endbell.
email Larry at:
[email protected]
Also his web site:
http://www.teamtamale.com/
rc1racer is offline
Old 01-21-2007, 04:49 PM
  #25
TheCoolCanFanMan's Avatar
Originally Posted by surrealmaterial
Hey Guys,
im in the process of trying to mount a small fan to blow air onto the endbell of the motor in my Xray FK'04.........any ideas???
thanks
Try wwwcoolcanfan.com
Cheers Malc
TheCoolCanFanMan is offline
  #26
Hey Guys,
thanks
Try www.coolcanfan.com
Cheers Malc
Old 01-21-2007, 04:57 PM
  #27
Originally Posted by jo90
Get the Much more endbell fan screws and then search the web for 30mm fans, alot cheaper than most of the options and alot more affective too !
As this guy is asking for one to fit his FK04 that houses a silver can, our kit WILL fit and do the job that he is after, and will look the part to.
Malc
Old 01-23-2007, 01:37 PM
  #28
I have a Topcad fan and heatsink to mount on my electric motor but am not sure where to plug this in. I am assuming that it plugs into one of the receiver ports but the wires are not long enough to reach. Any advice would be appreciated.
conrod51 is offline
Old 01-23-2007, 10:58 PM
  #29
more$thanbrains's Avatar
cut them, strip them, new wire, soldering, and shrink tubing in that order
more$thanbrains is offline
Old 01-24-2007, 07:28 AM
  #30
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
really? you cant shrink wrap them first them solder?? j/k
Marcos.J is offline
