Old 01-17-2007, 04:58 PM   #1
yeaklet4's Avatar
Trader Rating: 34 (97%+)
Default using novak milleuium for ib 38 and 4200
ok ive got a first verson of the charger and the mv only goes down to 4mv. but the batts are getting i would say very hot. but the 3800 took 4500 and the 42took 4700. i heard to charge them at at 3mv but is the diff between 3and 4mv a lot. i charged them at 5amp also thanks
yeaklet4 is offline   Reply With Quote
Old 01-17-2007, 06:30 PM   #2
Super Moderator
Grizzbob's Avatar
No, it's not that big a difference, I use aMillenium & Millenium Pro on mine, & frequently use a threshold of 4mV per cell, about that only time I go lower is when repeaking(I'll use the Pro & set at 2mV per cell for repeaks). Seems to work fine for me.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-17-2007, 06:46 PM   #3
yeaklet4's Avatar
does your packs get real hot on 4mvv setting
Old 01-17-2007, 10:31 PM   #4
Super Moderator
Grizzbob's Avatar
No, always stayed at a reasonable temp, & that's also with me charging my packs at 6-6.5 amps, too, don't think my packs have ever gotten above 140 degrees, if even that.....
Bob Seay
Go Pokes!!!
Old 01-18-2007, 04:49 AM   #5
Joel Lagace's Avatar
You got no worries then, the MAH readings on 10 chargers on the same pack would all likely be slightly different. IF they are not hot,buldging and spraying at the end of a charge your good to go!
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-18-2007, 04:54 AM   #6
Trader Rating: 69 (100%+)
youre charging 6 cells right? try setting the no. of cells to 4 cells, instead of 6, this will lower the total mv of the pack further
6 cells @ 4mv/cell = 24mv/pack
4 cells @ 4mv/cell = 16mv/pack
this might lower your peak temps but check for false peaking
marvi is offline   Reply With Quote
Old 01-18-2007, 02:45 PM   #7
sambonee's Avatar
Default hi
Shanna
This is Sean in Canada. Please let me know if the refund to Javier has been sent to his paypal. Thanks
Sean
sambonee is offline   Reply With Quote
Old 01-28-2007, 06:36 PM   #8
swopemike's Avatar
Use a temp gun, when you say "hot" this could be 120F or 140F or 160F. Instructions for IB 3800's tend to be 120 to 130F range is perfect. 4200's I have heard get hotter. 120F is standard HOT water off the faucet so use the temp gun so you know where you really are.
swopemike is offline   Reply With Quote
EP 4200 brians11 R/C Items: For Sale/Trade 2 04-27-2008 11:30 AM
4200 packs, DPD, Novak & Reedy BL Motors, Pro-Line tires, Losi Micro-T & more sale! chilly4kc R/C Items: For Sale/Trade 52 03-16-2008 08:00 PM
Novak GTB w/ LiPo cutoff and Brood IB 4200 WC's harkonen R/C Items: For Sale/Trade 6 05-12-2007 07:28 PM
Wtb: novak 5800 brushless+ ib 4200 mah batts Vincent_666 Australia Wanted to Buy 1 02-26-2007 11:45 PM
FS: Novak SS+ brushless system, 4200 stick packs, XR2i 75mhz radio, Duratrax Ice ttppll R/C Items: For Sale/Trade 8 01-30-2007 11:49 AM
