Motor Lathe Question >
Old 01-15-2007, 09:27 PM
  #16
protc3's Avatar
Originally Posted by raving-monkey
I'm quite confused about all this lathe malarky.
Well not the actual lathes but the speeds you run them at.
I run lathes at work, day in day out and generally speeding, on a smaller diameter and a softer material you run them at a far higher speed.
So if your running them at 500rpm for example, i cut steel at 700-1400 depending on the diameter.
I guess there must be a reason for running them slower...mainly because the lathe isn't fixed to a solid object? Or the belt would slip on the arm?
it is an interupted cut for starters and the work piece is not clamped solid enough to turn higher rpm's without casuing chatter.it is similar to running a long shaft in a cnc or engine lathe without a live center.
protc3 is offline
Old 01-15-2007, 09:29 PM
  #17
Team EAM
Trader Rating: 79 (100%+)
Speaking of Lathes Jason I am sending you mine to play with tomorrow. Get her fixed up and checked out for me!!
EA
EAMotorsports is offline
Old 01-15-2007, 09:32 PM
  #18
protc3's Avatar
cool,i will put it to the test.3 inch diameter titanium baby.
protc3 is offline
Old 01-15-2007, 09:40 PM
  #19
Team EAM
LOL....might need to put a new bit on it before jumping on something that size!!
EA
Old 01-15-2007, 11:43 PM
  #20
JasonC's Avatar
Trader Rating: 120 (100%+)
i have had almost every lathe out there and have found the orion to be the best bang for the buck. https://www.ssl-stormerhobbies.com/c...ns&pn=ORN41600
JasonC is offline
