Old 01-15-2007, 07:25 AM   #1
omaharich's Avatar
Default MaxAmps Lipo Thread!!
I just bought my first set of Maxamps 6000 Lipo and LOVE IT!!! Several of our local guys are running them and love them as well...We need a thread for them!! It would be nice if we could have a MaxAmps person in here sometimes to help explain some changes coming. I noticed there is a size change from a 6000mah purchased a few months back to the one I just received. Width and Depth the same but thickness is smaller.Have fun boys and girls!!!!
omaharich is offline   Reply With Quote
Old 01-15-2007, 09:34 AM   #2
padailey's Avatar
Everything going great with mine! Can't remember for sure how long I've had mine though... 6 months maybe with no problems. Need another for an enduro in April! Wooo Hooo!!
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-15-2007, 03:46 PM   #3
sportpak's Avatar
Trader Rating: 26 (100%+)
I have a 6000. I love it. I however switched over to a JRXS and now it won't fit. It's too bad, I love the LiPo. I may buy the type R JRX next summer. It's supposed to be LiPo friendly. All in all I am impressed with the MaxAmps battery. I do wish that the wires came out of the top, rather than the side. I could then run it in my buggy. As they evolve I hope that I can again use them.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-15-2007, 08:27 PM   #4
flying G.E.O.'s Avatar
So how do you guys maintain it? I think it has a balancing port and the battery doesn't have a secure casing. Its cheaper but are the cells made by kokam?
www.3dgallery.co.nr
flying G.E.O. is offline   Reply With Quote
Old 01-15-2007, 09:11 PM   #5
Trader Rating: 54 (100%+)
I have maxamps in both my T2(6000mah) and xx4(4400 saddle) and both are great. I agree on the wires though. Between the width and where the wires come out I had to do some serious mods on my T2 to make it fit. It was mainly just to wide and with the wires, I haad to cut my battery holders and shoe goo it to my battery strap to hold it in place.
jsmax is offline   Reply With Quote
Old 01-15-2007, 11:07 PM   #6
Darrell Skelton's Avatar
Default MaxAmps
Hey guys
You can get a Hyperion Lithium Balance Adapter from MaxAmps.com.
I got one when I ordered my 2100, 11.1 Lithium for my copter.
It's really cool. It hooks between your charger and you battery.
It balances as it charges. And it will do the balancing at the end if you want.
It balances from 2s to 6s. 10 amp max charge rate. Discharge mode autocut.
Charge, discharge, stand-alone balancer.
The number for it is LBA10, net6s+.
You can call MaxAmps and talk to Clint or Austin.
They can give you the scoop on it.
Darrell
Darrell Skelton
----- Team Wacko ----- MYKART Designs----- Slapmaster Tools
---------------Old Guys Still Race, CRS infected ---------------
Darrell Skelton is offline   Reply With Quote
Old 01-15-2007, 11:30 PM   #7
padailey's Avatar
Charge it and run it that's it. A couple of us share a balancer (Apache 505) but have found none of us have been out of balance. I've run my 6000 for 40 minutes just playing around and 33 minutes in an enduro with a 4300.
Tamiya TRF416X
Old 01-16-2007, 07:22 AM   #8
I have been running some 8000 off road for over a year. They are not ever any more out of balance then when I got them. It takes about 1 min for my balancer to level them out. Every pack I have tried from anyone takes about this long. We are talking about a very small voltage difference. I have no complaints on his batteries.
nichocgn is offline   Reply With Quote
Old 01-16-2007, 07:40 AM   #9
Racer4Life's Avatar
Trader Rating: 18 (100%+)
I just got a 8000 in a trade and bought a 3000 pack from them for a Rock Crawler project. I wanted to see if anyone knew if my Much More Cell master would charge these okay and how I needed to do it. I am totally new to Lipo and have the Kaboom fear in me!!
Racer4Life is offline   Reply With Quote
Old 01-16-2007, 09:03 AM   #10
padailey's Avatar
Ok someone can correct me but I think I've seen people on here talking about the Much More. I think the problem for lipo is that they only charge lipo at like 1amp? This will take forever with an 8000 or even a 3000 for that matter. Get a charger like the ICE that will charge at 1C so that you can charge the 8000 at 8 amps so it will only take an hour for a full charge. Then you would charge your 3000 3amps (1C). If you are new to lipos they charge CC-CV.. (constant current - constant voltage I think). So using the 8000 as an example your charger will charge at 8 amps until the voltage reaches 8.4V. Then voltage will stay at 8.4 and the amps will go down until the pack is full. Once you hit 8.4 the pack is probably 90% (guessing) full and the last little bit takes quite awhile to finish.
I wouldn't worry any more about the kaboom with a lipo as I would a NIMH. However do read up on lipos and charge correctly. Also don't run them too low and you'll love it. MaxAmps site has some info on lipos that you could read or check some of the other lipo threads here for more info.
Tamiya TRF416X
Old 01-16-2007, 09:09 AM   #11
Trader Rating: 69 (100%+)
i suggest you get another lipo compatible charger because the current much more charges at max 1 amp for lipo. it will take a very long time to fully charge your 8000
marvi is offline   Reply With Quote
Old 01-16-2007, 09:24 AM   #12
TheTurtleMan's Avatar
Trader Rating: 31 (100%+)
I have been running Lipo's for over a year. The Maxamps are great. I got a tour of the maxamps place, and them guys are way cool. Anyway, they tried blowing up a 6000 w/ and ice charger, and no mater what they did, couldn't get anything bad. They finally plugged it into a real car charger, and let it go for a long while. Then BOOM. I have seen many nimh packs go, but I am yet to ever see a lipo pack go. And I would also say that 1/2 the guys at my local track are using lipo's now. If some of those guys havn't blown one up, you really dont need to worrie about it.
Lipo
Charge rate. 1000mah = 1amp charge
6000mah = 6amp charge
CLICK HERE FOR ALL YOUR RADIO AND MORE SKINZ!!!!
http://www.rctech.net/forum/showthread.php?t=184104
WWW.BUSTOUTBMX.COM
TheTurtleMan is offline   Reply With Quote
Old 01-16-2007, 09:57 AM   #13
Racer4Life's Avatar
Okay! thanks guys. I read a little and found that the Much More is no good for Lipo charging. If I get a Ice, Orion, or other Lipo charger do I need to get a balancer?
Thanks and the guys from Maxamps sent me a thank you card for my order. That is going way beyond typical customer service!
Old 01-16-2007, 10:03 AM   #14
sportpak's Avatar
I bought one and now don't think I needed it. If you have a buddy or two that are running the Max Lipos, try to go in together on one. These batteries are really good.
Old 01-16-2007, 12:01 PM   #15
padailey's Avatar
I agree with sportpak about a balancer. You will rarely if ever need it but it is a nice security blanket. We had 4 guys go together on one and the first time we plugged it into the packs they were all balanced. If you can share one with someone that's the way to go.
Tamiya TRF416X
MAXAMPS LIPO PACKS HEAT Electric Off-Road 99 09-20-2008 09:55 PM
MaxAmps lipo and balancer upnover R/C Items: For Sale/Trade 1 05-29-2008 03:23 PM
MaxAmps 4400mah Saddle Lipo and Maxamps Balancer dr_hfuhuhurr R/C Items: For Sale/Trade 13 04-13-2008 08:37 AM
MaxAmps LiPo - 4S 5000mAh Mallanaga R/C Items: For Sale/Trade 45 02-29-2008 06:28 PM
Maxamps lipo and DN Power lipo packs harjo R/C Items: For Sale/Trade 2 12-02-2007 11:20 AM
