MaxAmps Lipo Thread!!
#76
So far I have bought a 4400 saddle lipo for my BJ4, and a 11.1v 4000Mah for a XXXCR. Both cars have Mamba's Bl systems and work perfectly. It took about a week to get the batts because I wanted 12g wire and Thunder power balancing connectors. I havent noticed any performance differances from my orion 3200/4800 packs. If I could charge at 2C, I would, but my Ice charger wont allow you to set it past 1C.
#77
#78
Set the pack capacity to 8800 mah if you are running the 4400s. Then set the max charge to 50% so it can't go over 4400 in the event of an error. This will charge at a 2C rate. This is how most lipo chargers are tricked into 2C rates. You have to remember, it'll lower the charge rate the second it hits 8.4V no matter how much capacity it has put in.
#82
Kuzo, when you say "50% of max charge", exactly what charger are you referring to? I use the mrc 977 and the steps are as follows:
enter number of cells-2 for 2s2p you get the drift. This automatically tells the charger to recognize what type of pack (lipo) and the cell configuration.
mah-6000 is what I use
amps-I hit it with the max of 5 amps
time to charge-optional
mv rating-I go gorilla, usually 35 or 40mv
Is there a way I can do the 2c charge rate on the 977??
#84
i use a mrc 989. it has a lipo max charge rate of 1.25c. though, i can fool it by saying it has about double the capacity. example:
i have a 4000 mah lipo. i tell the charger its 8000.
i set the rate to 8A. the chager allows it.
the pack charges completely, and reches 8.4 volts, and then sustains it. therfor, the pack cant be overcharged. thats assuming its rated at 2c charging though...
i dont think the 977 has such a high rate of charge available. and you mentioned MV rating? lipo's dont peak! if you are adjusting pmv on a lipo, your asking for an accident!
cheers!
cheers!
#85
cheers!
cheers!
#87
Here's the link to it:
http://fmadirect.com/Products.htm?cat=32&nid=24
Hope it helps...
