MaxAmps Lipo Thread!! >
Old 04-04-2007, 07:19 PM
  #61
wh
civiceg is offline
Old 04-04-2007, 08:46 PM
  #62
bxpitbull's Avatar
Default MaxAmps.com
MaxAmps.com is the place. They are very cooperative if ordering over the phone as well. When you buy from them, they send a thank you card and are very cooperative when asking advice.
bxpitbull is offline
Old 04-04-2007, 09:47 PM
  #63
ho
civiceg is offline
Old 04-05-2007, 05:13 AM
  #64
Originally Posted by padailey
The 4000 pack is made up of 2 4000 mah cells, each 6mm tall. 12mm + shrink =14mm.
The 5000 pack is made up of 2 5000 mah cells, each 9mm tall. 18mm + shrink = 20mm.
Thanks, it is interesting that 1000mah capacity increase increases the volume of a single cell by 50%...
cvt01 is offline
Old 04-05-2007, 05:48 AM
  #65
in this case, 1000 mAh is 20% more capacity and the thickness increases 30%. They're a little thicker that what you might expect but not that much.
Unregistered is offline
Old 04-05-2007, 10:07 AM
  #66
dougmartin's Avatar
Trader Rating: 14 (100%+)
Talking Help
HI all
I'm looking at getting a lipo battery and charger but not sure what to go with. All new to me...but want to try it out. I'm running a T2 with the Mamba max 7700. Any suggestions on what to look for or go with would be great.
Thanks, Doug
dougmartin is offline
Old 04-05-2007, 10:55 AM
  #67
padailey's Avatar
The 6000 is great because for a lipo it is very close in size to a regular 6 cell pack and the weight isn't outragously different. However a T2 is not real lipo friendly. Takes a little grinding on the motor mount to get it to fit. A 5000 might fit or at least take less grinding but you'll have to add a little more weight.
Plenty of charger options out there... I use the ICE.
padailey is offline
Old 04-05-2007, 11:56 AM
  #68
bxpitbull's Avatar
Default I use the MRC 977
I use the MRC 977. It has Li-Po settings, cut-offs and comes with it's own power supply. The MRC 989 is even better. Thing about MRC, they are very reasonable as far as price; especially considering they come with their own power supply.
Old 04-05-2007, 12:31 PM
  #69
Originally Posted by civiceg
how long does the shipping take?
I got my 6000mah pack from there e-bay store. The price is the same, but got the connector for free. I think if you get it from there web site, you get discounts as you spend more in the future. And i did get a thank you card from them few days later...kinda surprise me on that one...very friendly.
chumanji is offline
Old 04-05-2007, 12:32 PM
  #70
Oops...forgot to answer the question. I receive my pack in last than one wk.
chumanji is offline
Old 04-07-2007, 10:23 AM
  #71
Here is how I did the math:
4000 pack cell per your information:
44mm x 137mm x 6mm = 36168 cubic mm
5000 pack cell per your information:
45mm x 138mm x 9mm = 55890 cubic mm
55890 / 36168 = 154%
5000 / 4000 = 125%
That's why I say 50% bigger volume and 25% more capacity. It wouldn't be an issue but that makes it too thick to fit in the 007
edit: I just checked maybe I can make it fit... I mean the Platinum is 23mm thick and you have to put 1.5mm shims under the topdeck to make it fit...
cvt01 is offline
Old 07-25-2007, 07:04 PM
  #72
hey has any one had problems with max amps lipo's?
aus jd 2703 is offline
Old 07-26-2007, 05:46 AM
  #73
sportpak's Avatar
Trader Rating: 26 (100%+)
Performance was good. Had an edge get dented in a crash in my TC. Never used it again.
sportpak is offline
Old 07-27-2007, 01:52 AM
  #74
SammyZ's Avatar
Trader Rating: 138 (100%+)
I run maxamps 5000hv packs in my t2 007' and that car is tiiiiight fit. it fits like a glove and you can use tape ( I modded the T2 graphite strap). I also run maxamps 4400 li-po in my Jconcepts 4wd buggy.
SammyZ is offline
Old 08-16-2007, 01:05 PM
  #75
yyhayyim's Avatar
I called up MaxAmps and they confirmed over the phone that their Lipo packs can also be charged safely at 2C rate with a Balancer...that's great news, but I'd rather have them tell us that in writting....unless you bought a 3 yr warranty w/ your packs
yyhayyim is offline
