Old 01-14-2007, 05:13 PM   #1
LOSI123's Avatar
Trader Rating: 63 (100%+)
Default Electric Fan (where to plug it in on reciever)
Hi, I was after some advise on pluging in a heatsink fan into my standard spektrum reciever.
If all three channels are full, ie: steering, throtle , and personal transponder in channel 3/aux
can i plut it into the bat/tel socket , will this give power to the fan / will it wreck the reciever?
LOSI123 is offline   Reply With Quote
Old 01-14-2007, 05:15 PM   #2
ford_racing's Avatar
Send a message via MSN to ford_racing
You should be able to plug it into your Batt socket without any problems. I'm not too sure on spectrum but on all the other ones I've used therte has been no problems with running a fan off of the batt plugs
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 01-14-2007, 06:04 PM   #3
Yes - you should have no problems running it there.
I do without any hiccups.
duckman996 is offline   Reply With Quote
Old 01-14-2007, 06:18 PM   #4
Wild_Racer's Avatar
Send a message via MSN to Wild_Racer
I have mine in the bat socket without any problems
By the way I'm new here
Alex
Wild_Racer is offline   Reply With Quote
Old 01-14-2007, 06:41 PM   #5
The fan can be run on any socket on the reciever just make sure its the right polarity.
However, I suggest running your fan on the batteries. Meaning soldering your fan to the wires running to your cells connecting to the ESC. It'll make the fan more effective and running of 6V from the BEC.
Ben.C is offline   Reply With Quote
Old 01-14-2007, 06:51 PM   #6
Freewheelin4eva's Avatar
you should look at you fan and it will tell you what voltage it can run off of,
I had the expieriance where the LHS told me to just hardwire it to the batt. so it can get 7.2V. instead of the 6 it would get through the , well went through two trinity fans that way, but I am sure most fans can handle it, the much more fan I have now works. better fan I guess.
Freewheelin4eva is offline   Reply With Quote
Old 01-14-2007, 07:22 PM   #7
LOSI123's Avatar
thanks guys, I did it but it runs real slow,
Then i noticed the voltage it said on the fan (7.2v) so i hard wired it direct to esc lead that conects to battery and it runs much faster / better, it is a cheaper fan (3 racing)
thanks all for the advise!!
Old 01-14-2007, 07:22 PM   #8
Most of the RC fans are rated 5V. There are some that are more robust and can take 7.2V without dissintegrating them in a few runs. I get my fans from electronics shops that sells fan for mush lesser than one with a RC manufacturers sticker sticked on. I get mine for about US$3-4 or so and its still funning in my car from day one.
Old 01-14-2007, 08:21 PM   #9
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
had muchmore 30mm fan soldered on esc for a couple of training sessions and the sucker died in the middle of 3rd heat; emitting foul burnt smell
Yo!
KoE is offline   Reply With Quote
Old 01-14-2007, 09:50 PM   #10
pcar951's Avatar
Trader Rating: 19 (100%+)
Had a shorted fan glitch me into the boards in the main recently. Needless to say, I won't be plugging it into my receiver anymore.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy
pcar951 is offline   Reply With Quote
Old 01-15-2007, 01:18 AM   #11
AUSSIE BOB's Avatar
Default fan
Gday, if the fan is soldered onto the leads to the battery, that is, i use corrally and the leads run up to the male plugs, after a race and when marshelling, the fan/s still go and the motor is cooled down before you get back to it. I do have a radio switch but that is turned off after the race. If you go through the receiver when the radio is off, the fan is off, just a thought, plus Aussie rules state they run to the battery anyway
Thanks AUSSIE BOB
AUSSIE BOB is offline   Reply With Quote
Old 01-15-2007, 06:43 AM   #12
Skiddins's Avatar
Out of interest, does your Much More fan say 5V on ther sticker?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Losi/GRP Non-Tuned (Standard Plug) .21 vs the Tuned (Turbo Plug) .21 jsmax Nitro Off-Road 0 07-07-2008 08:17 PM
SPEKTRUM MICRO RECIEVER AND BIND PLUG bill marchant R/C Items: For Sale/Trade 3 02-12-2008 07:49 PM
Turbo plug Vs Standard plug mrhenning11 Electric Off-Road 1 04-16-2007 09:20 AM
Turbo plug vs standard plug shortygy Onroad Nitro Engine Zone 5 08-13-2004 04:10 AM
Getting Out Of Electric Sale *Lathe, KO Reciever, GT7, 12L3, CRC 3.2, Etc...* Leadfinger R/C Items: For Sale/Trade 38 06-30-2004 09:46 AM
