Xipp Super Lathe Trouble
I just perchased a used Xipp Super Lathe in great condition, but with no bit, I dug up some old post by Big Jim, and he said to use McMaster-Carr Carbide AL-4 Bits #3367A131, but the bit appears to be almost .5 an inch to long, I wind the lathe all the way out, and when I put the bit in it is already on the comm, is there an adjustment I am missing, or do I trim the backside of the bit down being as it is just soft metal?
Are you sure you have the bit in correctly? Are you sure you have the correct bit? Pictures always help if possible.
As long as you have a left handed bit the only thing I can think of is that you have it installed upside down.
thanks for the Heads up on the Bearings, I was going to order the carbide v blocks but if that works I will just take them out. On the Pic above see how the lathe is all the way open and the bit is right up agains the v blocks, that is what I am talking about, I emailed the guy who has this for sale and asked him if he trims them (no response yet) I wish Big Jim was still around
I see what you are talking about. Cutting the back of the toolbar should not hurt anything. I used the bearings until I kept finding all my motors were cutting weird, like half the comm would still have sharpie on it after cutting it. Took the bearings out and recentered the bit and it cuts fine again. Fine enough for me anyhow, the carbide blocks sound like the best idea though. Do you have a link for them?
Originally Posted by SpeedySST
I have the same lathe and it appears to me that the bit is a right handed bit not a left hand.
Well I trimmed down the bit and it fits fine, Now I have another question, I have a Duratrax Ice, says it runs lathes, ok, so I connect my lathe to it, starts to turn for 4 sec then says motor disconected, so I try just running the motor, works fine, so I try the lathe again, runs for a few sec then, beep beep beep, motor disconected, I have checked, the clips are on the lathe, WHAT IS GOING ON??????????
I had the same problem with my ICE when my lathe was new. I cut a couple of motors running the lathe off a battery and the o-ring seemed to break in. I can run it off my ICE with no problems now.
I bought one of the Integy 55t motors, that Reedy Mvp in the lathe was pulling down some serious amps, thanks to all for your help, I am new to electric and just learning about all the terms and what they mean etc.., So I take it the 55t will draw alot less amps
