Gm Brushless Systems >
Old 01-15-2007, 05:58 AM
  #16
AngryAsian's Avatar
Should've stuck with the GTB andy! LoL..
oh.. but glad to see you ditched the schu for the Cyclone. YOu still at the shop?
In the GTB's case - a stuttering motor was usually a sensor problem and had to be sent back. Hopefully you can sort it out. I experienced it once - turned out to be a bad sensor harness.
AngryAsian is offline
Old 02-14-2007, 07:37 PM
  #17
will the GENIUS 80 run both sensored & sensorless motors ??
http://shop.graupner.de/webuerp/servlet/AI?ARTN=7167
GENIUS 100 .... something better then the 95
Rojna is offline
Old 02-15-2007, 12:54 AM
  #18
Eirik's Avatar
The Genius 80 will handle both sensored and sensoless motors!
The Genius 100 is the same speedo as the 95, just a different casing for more cooling.....
Eirik is offline
Old 02-15-2007, 06:44 AM
  #19
Martin Hofer's Avatar
and a new software where no additional programming is needed
sorta plug and play :-)
Martin Hofer is offline
Old 02-15-2007, 10:41 AM
  #20
Soon the handheld programmer will be out, hopefully that will make it easier to adjust it.
moonman is offline
Old 02-15-2007, 10:59 AM
  #21
GM 2007 products
http://www.gm-racing.de/rwdownload/d..._racing_07.pdf
Cad image of the genius 100
moonman is offline
Old 03-02-2007, 12:41 PM
  #22
subman's Avatar
I can't find my manual right now and my car is stuck in heli mode can someone tell me how to get back to forward/brake mode.
or a link to the manual online
Thx
subman is offline
Old 03-02-2007, 03:18 PM
  #23
switch on, wait for beep signalising mode, push and hold set button for 4 secs then you'll hear "beeeep ... beep beep"
forward
brake (and hold brake)
than you'll hear 2 beeps signalising mode selection is done
You see many people ask me bout this, even though they have their manual :-) I know the escs signals by heart
Old 03-02-2007, 04:07 PM
  #24
subman's Avatar
thanks so much!!! any tips on using it?
subman is offline
Old 03-03-2007, 10:20 AM
  #25
what you mean with tips?
what parameters should be set?
here's the most important stuff I'm currently using
maxamp 200 (maybe sometimes as low as 150, depending on track)
softgas 100
turbo 5 (2 - 5 depending on track)
Timing 30°
minbrake 15
maxbrake 85
fullbrake 90 (with spool)
reserved 6
frequency 1
Old 03-03-2007, 11:49 AM
  #26
Hi
Can anyone send me the manual for Genius 95/100?
English prefer.
thanks alot
RC Synergy is offline
Old 03-04-2007, 04:23 PM
  #27
syndr0me's Avatar
Trader Rating: 32 (100%+)
Has anybody run the Genius ESC with a Novak motor? If so, what kind of results do you get, with and without the sensors connected?
syndr0me is offline
Old 03-05-2007, 09:47 PM
  #28
syndr0me's Avatar
http://shop.graupner.de/webuerp/servlet/AA?wgr=853
It looks like GM's new motors are coming to market soon. There's all kinds of interesting stuff, including some motors available as star/wye or delta winding.
syndr0me is offline
Old 03-05-2007, 10:25 PM
  #29
subman's Avatar
I'm having a problem with it stuttering (like it's missing a phase) and when it does run it cuts out. I'm going to change the motor and see if that helps
subman is offline
Old 03-05-2007, 10:26 PM
  #30
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Possible short in coil? Been there.
UN4RACING is offline
