Old 01-10-2007, 09:15 PM   #1
peded's Avatar
Default Power Sources for Parking Lot races
I was wondering for the up coming outdoor season what would be a good energy source for running parking lot races?
Would the following options viable:
- Car Battery -> Power Distribution Box -> what ever
or
- Car Battery -> Inverter -> Power Supply -> Power distribution Box -> whatever
Do you have any suggestions or ideas for this solution? Thanks.
peded is offline   Reply With Quote
Old 01-10-2007, 10:05 PM   #2
A good deep cycle marine or car battery and dist. box for the 12 volt stuff and an inverter for your 110v. You don't need your powersupply as everything can be hooked directly up to the battery.
Johnny9s is offline   Reply With Quote
Old 01-10-2007, 10:07 PM   #3
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
a small generator ,perfect for the summer ,run everything plus a fan
Old 01-11-2007, 05:39 AM   #4
Skiddins's Avatar
If your going to use a large lead/acid battery try to get a 'Leisure Battery' instead of a normal car item.
Car batteries are designed to give a huge amount of power for a short period (starting the car) then the alternator takes over.
Leisure Batteries are designed to be used in caravans/boats etc where power requirements are lower but more constant.
They look exactly the same.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-11-2007, 06:16 AM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
You can also check radio shack, they carry a power converter that plug's into the lighter of your car. I use them to charge my tool batterie's.
And affordable, built in cooling fan and you can run a tv and nintendo on your trip to the track.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 01-11-2007, 09:24 AM   #6
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I managed to get a few used SLA batteries from a huge UPS system my company was upgrading.. It had 24 car-battery sized cells to replace, so I took a few of the best ones off of their hands. They're not in peak shape, but still last a whole race worth of charging and soldering.. Frickin heavy, though.. If they do get any worse I can run them in parallel with each other or the car batt to share the load, all from the trunk..
Cool thing is that the terminal screw holes are the same size as the banana plugs, so in goes the distro box, and that's it!
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 01-11-2007, 10:32 AM   #7
rcgen's Avatar
EU2000 honda generator is what I use. Provides provides everything I need real quiet plus you can go the whole day on one tank.
http://www.hondapowerequipment.com/M...elName=eu2000i
rcgen is offline   Reply With Quote
Old 01-11-2007, 10:51 AM   #8
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
I would second the little honda generator, they are great little units...Check your local Pepboys, they have been running great deals on generators lately...
When I run only nitro at a parking lot track I use a 110 power inverter if I need a iron or anything like that and I hookup a charger to my car battery for my receiver and transmitter pack, works great, I start the car up at lunch and let it run for a few minutes to be sure I dont need a jump
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 01-11-2007, 11:02 AM   #9
chicagokenji's Avatar
Default races
you mention running races....using ohm's law if I showed up at your track I'd need at least 240watts continuous if me and my boys were to race electric at your place. 3 chargers at 6amps each and a soldering iron.
Your power supply should be dependant on how many people will be pitting there and what kid of vehicles they are racing.
I've used both generators and deep cycle 12 v batteries. I've also ruined my minivan's car battery at the track.
chicagokenji is offline   Reply With Quote
Old 01-11-2007, 11:58 AM   #10
Speedie's Avatar
If you cannot afford a generator you can make one. I found a lawn mower in the trash that someone had ran over with his truck took the motor from that. an old used alternator I found lying around welded a old small block chevy crank pulley to the hub for the blade. Found a nice deep cycle battery in the boat my cousin has been storing in my shead. Added a little fabrication skill and my power inverter and walla a generator for about 20 bucks. I had to buy a few bolts a belt and some paint. Its heavy and loud but cheap. Plus I sold it to a guy for his hunting shack for 300 bucks. I did keep my cousins battery tho. lol
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 07-08-2007, 07:57 PM   #11
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Generator
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 07-08-2007, 09:38 PM   #12
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
Hamster wheel.
Sean R is offline   Reply With Quote
Old 07-08-2007, 09:45 PM   #13
Tech Legend
Wild Cherry's Avatar
or
Try looking inside a lite pole base and spice in a connection ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-08-2007, 09:46 PM   #14
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
They have electricity at HT don't they?
Rusty Andersen
thercbarn.com
$rusty$ is offline   Reply With Quote
Old 07-09-2007, 04:33 AM   #15
generator--cheap ones are noisy . If you like noise get any generator if you like QUIET spend the extra bucks for the invertor type by Honda or Yahama.You'll appreciate it and so will your fellow r/cer's.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Las Vegas Hobbytown parking lot races trdsupra88 Arizona-New Mexico Racing 479 11-19-2015 03:45 PM
Radio Controlled Racers of Northern Virginia bjames Racing Forum 5283 07-22-2012 04:36 PM
speedtech holding parking lot races... racer x 1 Racing Forum 1 06-27-2008 12:26 AM
Sources of Entertainment......! prince007 Chat Lounge 30 10-12-2006 05:29 AM
Your Thoughts on Parking Lot Races charlie_b Racing Forum 48 07-01-2005 06:06 PM
