Old 01-10-2007, 08:49 PM   #1
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default Tamiya "DJ" Pro-Module Rear Suspension System
Hi
Has anyone are useing or had those on their car on TA05,415,EVO5???
Like to hear some feed back..Thanks
It is worth of buying it?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-10-2007, 08:52 PM   #2
hierog's Avatar
do they still sell it? i thought it was a limited run from about 2 years ago? anyhow, i bought a set and one of the uprights was way off. it took tamiya almost 4 months to replace it for me and i never put it back on!
vic
hierog is offline   Reply With Quote
Old 01-10-2007, 09:12 PM   #3
OVA
OVA's Avatar
vic
wow that bad....jzee
What is the ideal of using it?? does is make the rear end more rear traction??
Old 01-10-2007, 09:18 PM   #4
Korey Harbke's Avatar
From looking at the design, the suspension should produce more overall grip. I think thats what Mr. Garber always said too... it was a little too stuck for him. It's always something to try though.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-10-2007, 09:27 PM   #5
OVA
OVA's Avatar
-Korey
Hey Korey
That's what I'm thinking too...
Old 01-10-2007, 10:20 PM   #6
Jimmy Morris's Avatar
Im pretty sure I remember reading it was suposed to make you able to run a stiffer spring and still keep the rear end stable or something.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 01-10-2007, 11:02 PM   #7
OVA
OVA's Avatar
Your right Jimbo .. from the picture of the rear shock position look closer to hing pin ,it may allow to use the stiffner spring....
Old 01-10-2007, 11:14 PM   #8
maxepower's Avatar
Unhappy
Originally they were made here in the U.S. Now they are made in Japan and imported. The 2nd batch that was made here was machined improperly and the rear toe wasn't equal from one side to the other. I believe this has been corrected in the Jap version. Ran it in my 415 for one season. Worked well but once you hit a dot hard the arms bend very easily. If they made a plastic graphite version I would definitely try it again.!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-10-2007, 11:34 PM   #9
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
It's actually the other way. The spring/shock attach directly to the upright, not the arm, so you run a WAY softer spring since the arm isn't multiplying the leverage applied to the spring. The spring only "sees" the actual (or really close) corner weight.
No idea how it handles...but that's how it works, leverage-wise.
Turbo Joe is offline   Reply With Quote
Old 01-11-2007, 12:01 AM   #10
Default DJ
I have the DJ, it was installed on my 415 but after I learnt abit more about setting my car up I found I didnt need it anymore.
However lately I have bought an MRE 415 and that thing is nuts, nailing it out of the corner made the bloody thing drift so I installed the DJ pro just to see what it would do and it made huge difference, I could give the car full beans on exit and the ass would just stick. But, they are supplied with the red springs, when you run blue springs on the front like the manual says, with a real soft spring like the reds, course the ass will behave itself, so I took the DJ pro sus off and put the stock on with soft springs, less droop - almost the same result.
I have seen alot of setup sheets for the 415msx with spools and almost all of them have the DJ pro fitted, eg David Juns 415
So I dont know, I wouldnt bother fitting it to the TA05 or the Evo 5, they handle so well already
Hope that helps
junn is offline   Reply With Quote
Old 01-11-2007, 12:19 AM   #11
Runin Ronin's Avatar
Just want to add the the DJ Pro was designed for asphalt racing... don't think it'll be much help on carpet.
Runin Ronin is offline   Reply With Quote
Old 01-11-2007, 09:50 AM   #12
Trader Rating: 30 (100%+)
I've run my Pro Module on my EVO IV and the car handled so well. It was extremely responsive, but controllable. This was on a prepped indoor track which is now closed. I tried running it on asphalt and I didn't see much difference between the stock and Pro Module. In my opinion, I don't think it was really worth it especially since you have to worry about damaging the arms.
wrxnfx is offline   Reply With Quote
Old 10-19-2016, 12:36 AM   #13
I know this is a super old thread, but just had a question about installing on it my TA05R V2 (ifs) - I forgot I had this in my spare parts bin and wanted to give it a shot.
The current rear uprights use a 1050 bearing and the pro module uprights use a 950 bearing. Are axles specific to the bearing size?
jessele is offline   Reply With Quote
Old 10-19-2016, 12:44 AM   #14
gigaplex's Avatar
Axles require a specific internal diameter from the bearing. Since both 950 and 1050 have a 5mm internal diameter you should be good to go.
gigaplex is offline   Reply With Quote
Old 10-19-2016, 01:53 PM   #15
Thanks for the confirmation! Wanted to confirm before I opened up the package.
Tamiya Pro Module Rear Suspension AWK Electric On-Road 2 07-26-2007 06:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Tamiya "DJ" Pro-Module Rear Suspension System MDawson R/C Items: For Sale/Trade 1 10-24-2005 12:54 AM
Tamiya "DJ" Pro-Module Rear Suspension System acutts R/C Items: For Sale/Trade 2 08-19-2005 05:59 AM
Tamiya "DJ" Pro-Module Rear Suspension System pink pac man Electric On-Road 92 06-10-2005 02:18 AM
