ESC for 8 turn motor? >
Old 01-09-2007, 07:46 PM
streetracer745's Avatar
Default ESC for 8 turn motor?
i need a speed control that can handle down to a 8 turn motor. 9.20 gear ratio and typically will be goign close to if not full throttle on a big sweeping track. might be used for 4wd buggy racing too with almost the same gear ratio. what is a good ESC for under $100? or is there one?
streetracer745 is offline
Old 01-09-2007, 10:42 PM
bxpitbull's Avatar
Duratrax intellispeed 8 turn forward only. Novak Dually.
bxpitbull is offline
Old 01-09-2007, 11:28 PM
Those 2 are good...If you don't mind buying a little more, get the Novak GT7, which has no motor limit.
Ben.C is offline
Old 01-10-2007, 01:56 PM
i was told that the diratrax was bad? i heard you were a lot better off with something else. how much is the GT7?
Old 01-10-2007, 03:35 PM
gubbs3's Avatar
The GT7 is a great esc. I picked one up off ebay for les than $60.
gubbs3 is offline
Old 01-10-2007, 03:40 PM
Mans343's Avatar
I bought a Duratrax 8T intellispeed forward only for $80.00 brand new! and I have not had any problems with it so far and i have had it for a 1year 1/2!
Mans343 is offline
Old 01-10-2007, 03:55 PM
im tempted to forget brushed motor and get a mamba max system...... cause right now its going to cost close to $120 for brushed system. the mamba max is $60 more yes but will take no maintenance and can just drive no matter what the gear ratio is. if i get the mamba, im nto going to have much money to spare, but it will have less maintenance and save up over time. right?
Old 01-10-2007, 05:48 PM
RCpurplecow's Avatar
get the mamba, brushless is no maitenance.
RCpurplecow is offline
Old 01-10-2007, 05:52 PM
fatbear's Avatar
New MTroniks IP6
fatbear is offline
Old 01-10-2007, 06:37 PM
can i get a link for the MTronics? is it brushless? if so is it sensored or not? i actually was thinking of putting a team checkpoint armature in my speed gems for like $20 the nget a new speedo, which would be a pretty good deal, i think, but brushless will save up over time cause i wont have to buy a lathe or armatures and brushes and stuff
Old 01-10-2007, 06:48 PM
ROBORAT's Avatar
yes, brushless would be a very good option for you. savings over time and less maintenance is a big plus for going BL. there are many good systems out there (Novak, LRP, Mamba, GM, etc) to choose from and BL technology has gone a long way ... very reliable and insane speeds (esp the 3.5 motors). the initial out of pocket might be bigger but in the long run the savings will be worth it.
ROBORAT is offline
Old 01-10-2007, 06:52 PM
yeah im running the LRP sphere/ Reedy Neo-one 4star system in one of my cars. its amazing power and speed. it will do close to 60 and will smoke the tires. this is goign to be an alternative motor between a 4wd buggy and another tc that i dont race. so i was looking for more of a 5.5 or 6.5 if snesored. 7700 if sensorless. what is a good sensorless system other than the mamba max?
