Batteries
First time building a battery pack and need help on how to build. Also which battery to get, looking at team orion.
I was told very specifically from a good source to heat the ends of your cells for a maximum of 8 seconds. Then let it cool. Do not reapply heat until the cell is cool and do not do the other end until the cell is cool.
Thats what I usually do...I do not expose the cells to heat for too long.Not good for them.IB usually don't like high temps. I'll cool them before the next round of soldering...
If you want great packs go with ProMatch.
They have assemblies that you can choose how to have the pack assembled, or you can get the 6 or 4 cells so you can put the pack together. Very high voltage, and good runt time, and plus they match them at 35 amps!!
Chris
Chris
thanks for info guys...we are running a losi jrxs and concerned if some cells will fit. are 4200 the same size around as 3200? also if we run stock class can we run the larger cells? thanks again
ouch thats what I was afraid of ! what kind and how minor? really didnt want to modify this chassis
try here ... www.fusionbatteries.com !!!! they come pre build to the configuration you want and have the power you need !!!! at great prices ...
Good luck at the races !!
every single reply that has recommended a battery seems to be sponsored by that company.
does anyone have an UN-BIASED answer please?
Trader Rating: 7 (89%+)
If you are a new racer, don't spend all your money on team pack, just buy a decent pack and learn how to driver first. try 5 minutes without touching the side !!!!
Go with an assembled pack man, the matchers are the best qualified to assemble a pack normally andif you have never done it before I would suggest not starting out with the new cells out there. Alos if the guy's who are good enough to have a sponsor are telling someone to buy assembled packs don't you think they have enough experience to know the best way to go?
Just my 2 cents
If you like Orion batteries, Peak Racing works very closely with them and get's all their batteries supplied and matched at the same facility by the same people in Switzerland. And Starting in 2007 (I.E. now) you can call Peak Racing directly and talk to Rick Hohwart or Joe Pillars directly and custom order batteries and even have them pre-assembled!
