Old 01-07-2007, 04:01 PM   #1
streetracer745's Avatar
Send a message via AIM to streetracer745
Default good soldering iron?
what is a good 40-60 watt soldering iron for a good price?
http://www2.towerhobbies.com/cgi-bin...&I=LXPR36&P=ML
is that any good or should i get a nicer oen from my LHS?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-07-2007, 06:06 PM   #2
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
watch ebay for a weller adj digital iron, you can get one for about 50 usually, very good iron. metcal is an awesome iron thats all i will use. im an electronics tech and do class3 soldering on 100k$ boards and these irons are up to the task.
loopedout is offline   Reply With Quote
Old 01-07-2007, 06:16 PM   #3
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Skies the limit on irons I've soldered my self to the weller's. (Weller 40watt).
The tips on those in your link are steel, I think, and they last,but the weller perform's.
I cant think of the name of the more exspensive one but the one's the guy's at the track are using are adjustable temp and the tip's appear to be lasting forever. The weller tips are wide but you have to file them from time to time to keep the wedge on the tip. You should be able to get one at the track or hobby shop. Very affordable. I would stick to the weller tryed and true for me 10 years. Probably went through 3.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 01-07-2007, 06:17 PM   #4
so the one i put a link to is crap? stay away from it? anythign i could pick up for around 30 at the most that will be good?
Old 01-07-2007, 06:22 PM   #5
UN4RACING's Avatar
Your funny. No it's not crap it's cheap.
Old 01-07-2007, 06:25 PM   #6
UN4RACING's Avatar
Any cheaper? Just use your lighter.
Old 01-07-2007, 06:27 PM   #7
hey man im new to soldering irons. i can solder, but dont know crap bout the irons and whats good.
Old 01-07-2007, 06:37 PM   #8
Slotmachine's Avatar
Send a message via MSN to Slotmachine
GO HERE this iron is just like the Hakko one and its cheaper. Just get a wide chisel tip for it and you will be o/k. I have one and I solder batteries with mine all the time.
Paul..............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-07-2007, 06:41 PM   #9
which one? there are 4 on htere. which one is better?
Old 01-07-2007, 07:45 PM   #10
I have the 936 , like I said buy a wider tip for it and it will be great.
Old 01-07-2007, 07:52 PM   #11
anything for less than $55?
Old 01-07-2007, 08:21 PM   #12
Castradamus's Avatar
Trader Rating: 53 (100%+)
FYI, If you buy that soldering iron from therer website the cheapest shipping is $16.00. If you buy it from there Ebay store it is only $10 dollars
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 01-07-2007, 08:23 PM   #13
swopemike's Avatar
Radio Shack handheld gun $29.99, 230 W max (has a lower W position also). Great for batteries too. The tips don't handle the high heat well probably because they get so hot. Heavy and cumbersome, but if you want cheap, it gets the job done. I killed two of these by clamping the switch to the high position for too long a few times and it melted and eventually fried itself until it became unsafe to use, then I bought the 80W adjustable Weller $65 works great so far (couple months).
swopemike is offline   Reply With Quote
Old 01-07-2007, 08:25 PM   #14
im not goign to be using it much. i dont build my batteries much if ever. i will just need it to solder wires on motors. maybe a battery every now and then. thats why i figured one for $6 of the site i showed might be ok since i will hardly ever use it.
Old 01-07-2007, 08:41 PM   #15
sharkman's Avatar
Trader Rating: 17 (100%+)
This is the best soldering station you will ever own for $46.
I have had this for 4+ yrs and it stay on all the time at the races on full power. Always hot and ready for any job. Comes with a large chisel tip as well.
Some will say that the hako is the best but with your $$$ requirement, you will be more then pleased.
http://www.jameco.com/webapp/wcs/sto...oductId=146595
sharkman is offline   Reply With Quote
Best Soldering Iron? snoopyrc Radio and Electronics 30 11-21-2010 10:52 PM
good soldering iron? aus jd 2703 Electric On-Road 50 09-18-2007 07:28 PM
good soldering iron? aus jd 2703 Australian Racing 17 08-26-2007 04:53 PM
Busted my soldering iron... goot irons any good? JusBox Electric On-Road 71 02-23-2007 09:18 AM
DC Soldering Iron Guo Chean Electric On-Road 2 01-03-2005 12:02 PM
