soldering reedy neo-one motor help? >
Old 01-06-2007, 12:48 PM
streetracer745's Avatar
Default soldering reedy neo-one motor help?
i want to put the wires on my neo-one 4star motor onto the other side of the plate. right now they stick over the motor itself and i want them going away from the motor. i tryed soldering them, but the stuff holding them on now wont melt with my soldering gun. how should i do that
streetracer745 is offline
Old 01-06-2007, 01:10 PM
tmaxxking's Avatar
Trader Rating: 19 (100%+)
Default .
sounds like the iron your using doesnt have enough watts
try some flux then use the iron on the solder
or find a buddy with a hotter iron
tmaxxking is offline
Old 01-06-2007, 01:31 PM
is it safe to cut the wires off then solder them to the other side with my own solder? just solder it on to the stuff already on?
Old 01-06-2007, 01:39 PM
Tech Legend
Wild Cherry's Avatar
Streetracer, you can solder the wires on the back side of the tab but be carefull because its very thin metal on that side...
suggest you solder to outside where the metal tab is thicker....
Wild Cherry is offline
Old 01-06-2007, 01:48 PM
but my soldering iron doesnt get hoit enough to melt the solder on the back side. is it safe to cut the wires off and then solder them onto the other side ontop of the existing solder?
Old 01-06-2007, 02:04 PM
Tech Legend
First,
get a good hot iron....
and
yes, you can do as you ask , just make sure none of the solder gets on the tab next to it...
Old 01-06-2007, 02:08 PM
tmaxxking's Avatar
Default .
i would borrow an iron from a buddy or pick one up
you will end up with bad connections if the solder doesnt get hot enough
mine is older and needs a new tip. and i do need a hotter one. but for now this is all i can use because i dont have the money to get another one. so if i cut the wire right next to the tab and solder it to the other side it will still work fine? i cant afford to mess up this motor and get a new one. i dont have that money.
Old 01-06-2007, 02:47 PM
Old 01-06-2007, 02:54 PM
sorry to be trying to find out so fast but i would like to know soon. i would like to do it before my race tonight
Old 01-06-2007, 04:02 PM
Tech Legend
Be patient, and have someone with a good iron assist you...
Old 01-06-2007, 08:58 PM
if its safe to just cut the wires then resolder them to the other side its fien that my iron isnt good right now. and when i get a better one ill redo all of it to make sure it holds.
