Old 01-05-2007, 06:48 PM   #1
Default Show me pics of your spektrum antennae install!
I am having trouble getting my spektrum antennae to make it to where the stock antennae tube mount is.. I want it to be vertical, as the spektrum manual calls for this. How did you guys do it?
My car is a TB-02, but I'm sure it is similar on all 1/10 road cars..
Jason
JasonRP is offline   Reply With Quote
Old 01-05-2007, 06:59 PM   #2
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Are you running the pro reciever? Im just running the antenna without even trying to run it to the antenna mount of tubing. Just try to make it straight so it stands up straigh on its own. The range is so great, you could even buddle up the antenna. (correct me someone if im wrong.) Sorry but i dont have any pics of my car. I run the RDX. I hope this helps, and maybe somone else could post a pic of theirs to give you a better understanding.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-05-2007, 07:06 PM   #3
SoCalMitch's Avatar
I ran into the same problem as you did, so I just made a antenna mount right on the receiver. I use a plastic round spacer that the tube could fit into and glued the spacer on the receiver over the antenna hole. Then I made the antenna hole in the case larger so that the tube could slide more into the case.
SoCalMitch is offline   Reply With Quote
Old 01-05-2007, 07:48 PM   #4
stiltskin's Avatar
Trader Rating: 102 (100%+)
I used to run the antenna under the servo and never had any problems. Now I just wrap the wire up in a coil (pig tail) and tuck it away.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-05-2007, 08:33 PM   #5
Send a message via ICQ to rcnewb2004
Got a pic stiltskin? hehe
rcnewb2004 is offline   Reply With Quote
Old 01-05-2007, 09:08 PM   #6
stiltskin's Avatar
Kinda hard to see. I'm not a wiz with the camera.
Tony Rumple
Old 01-05-2007, 09:14 PM   #7
you are a wiz with the wiring though... looks amazing dude! (though i am still searching for your antennae right now)
Old 01-06-2007, 10:32 AM   #8
I have glued a short piece of antenna tube to the top deck of my FK05. It's the green tube in the pic. I can route it away from everything else and it is streched out lone enough to give good distance outside.
rollover is offline   Reply With Quote
Old 01-06-2007, 01:05 PM   #9
James35's Avatar
I took an exacto knife to my antenna tube. Made a 1/4" incision on one side of the tube. Then I took needle nose pliers, opened and flattened it. Then I superglued it to a bigger piece of lexan which can easily be servo taped to the side of the receiver.
James35 is offline   Reply With Quote
Old 01-06-2007, 08:06 PM   #10
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I just run my antenna straight up out of the reciever. Doesnt really move much.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-06-2007, 08:16 PM   #11
AdrianM's Avatar
I don't bother with an antenna tube. I just let it stick up from the receiver on my micro Rx. On my regular Pro RX I cut the antenna to 3.6" and I let it just stick up too.
Adrian Martinez
Old 01-07-2007, 03:21 PM   #12
cfwdude's Avatar
A little bit of extra lexan, little servo tape, heat the lexan to bend, (so it can bend lower if need be to fit under a body or top plate) and coil the antennae around the lexan. Little tape to keep it in place.
I switch recievers around between a few cars, so this also keeps it simple for moving it around.
cfwdude is offline   Reply With Quote
Old 01-07-2007, 03:29 PM   #13
steve a.'s Avatar
Send a message via AIM to steve a. Send a message via MSN to steve a.
I mounted my receiver on top of my servo and ran the antenna down the side of the servo then up the antenna tube and bent the tube so it doesn't even extend out side the body
Starcar Vice President come check us out
www.starcarrc.com
steve a. is offline   Reply With Quote
Old 09-11-2007, 12:52 PM   #14
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
See attached
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-11-2007, 08:29 PM   #15
mac853's Avatar
Originally Posted by Nova F1 Racer View Post
See attached
Yes, there's from manual, but could somebody explain to me if it means since from the board then from the cover, please.
mac853 is offline   Reply With Quote
Car Show Pics rltanner Chat Lounge 34 08-17-2008 01:16 AM
SHOW ME YOUR PICS marie Chat Lounge 65 11-13-2007 12:54 PM
show us some pics of ur car ntc3freak Malaysian R/C Racers 156 07-29-2005 11:50 AM
show us some pics of ur car!!! ntc3freak Nitro On-Road 5 02-28-2005 09:01 PM
Schizuoka show 04 pics? sac Electric On-Road 25 05-19-2004 12:16 AM
