Old 03-04-2003, 11:17 PM   #1
rc-racer's Avatar
Default What pack should I use...
Ok, I have two packs, both never run.
Pack 1 Sanyo 3000-HV NiMH has these numbers -
1.145 volts, 1.145, 1.146, 1.147, 1.148, 1.149
6.0 Chg
30 Dis
0.90 cut off
Pack 2 GP 3300 NiMH has these numbers -
1.123 volts, 1.123, 1.124, 1.124, 1.124, 1.124
5.0 Chg
30 Dis
0.90 cut off
What pack should I use for practice and what one should I use for racing?
rc-racer is offline   Reply With Quote
Old 03-05-2003, 12:36 AM   #2
Send a message via AIM to Leon
The GP3300 has longer run time than the 3000HV right? I would say run the GP3300 in practice if you race in stock, if you run in mod. Then run the 3000HV in practice. Runtime is more important in mod and voltage is more important in stock.
Leon is offline   Reply With Quote
Old 03-05-2003, 12:49 AM   #3
Cole Trickle's Avatar
Agree. Especially for stock. For mod the above is a good starting point, but the 3000 have better voltage, so you might want to do some testing about runtime with the 3000's.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-05-2003, 01:28 AM   #4
Herminator's Avatar
Send a message via ICQ to Herminator
Best test is on the track, both should last a race. Unless you tested them yourself then the numbers for them are only really good for comparing the same kind of cells tested by the same company. I've heard that generally 3300's have more punch for stock, especially GP's, 3000's are generally best for mod racing, 2400's are still better than 3000's for stock racing. Best just going out and giving them a try though.
Herminator is offline   Reply With Quote
Old 03-05-2003, 05:37 AM   #5
Trader Rating: 24 (100%+)
Personal suggestion...don't use either for practice. In the long run you would be better off buying a couple of cheap stick packs or some used matched packs from the rctech classifieds or other" for sale" sites. Save your good packs for the track and some quality charging !!! Good Luck
Evoracer is offline   Reply With Quote
Old 03-05-2003, 07:05 AM   #6
I agree it's good idea to save the best packs for racing. But depending on how often you race... If you (like me) race once a month, then the packs get noticeable slower, if resting for a month. In this case you'll need to cycle the packs before racing... So you might as well use them regularly... But it's still a good idea to supply with more packs, so you dont use your good packs too hard.
Dont charge them while hot ! And if you dont already got one, do yourself a favor and by a good charger, which are NiMh compatible. It'll save you money in the long run, since your packs last longer. And as a bonus, run faster !
Old 03-05-2003, 09:56 AM   #7
rc-racer's Avatar
Thanks for the great tips guys!
I'm new at racing so I thought it would be better for me to start off running stock.
For a charger I just picked up a Pitbull, it should do the trick.
Thanks again guys.
Brushless 9.5 rtr, Lipo pack, Elite 1500 pack, 18t alum parts NIB maddog2099 R/C Items: For Sale/Trade 3 09-02-2008 07:09 AM
IB 4200 6 Cell Pack Nice Pack Good Numbers 27.00 Shipped rcdreamer95 R/C Items: For Sale/Trade 0 03-02-2008 12:55 PM
Charging 3pk battery pack (8 cell 2400mah Venom NIMH pack) mcgmark Electric On-Road 2 11-06-2006 08:57 AM
RC18T w/Baja Motor, 6Cell Matched Pack, 7Cell Pack JustBuggin R/C Items: For Sale/Trade 0 05-08-2006 01:27 AM
JR R-1 800mAh battery pack, charger cord [Tx & Rx pack], (8) 700mAh Nicads + cradle Tom G R/C Items: For Sale/Trade 2 08-17-2004 03:46 AM
