Old 01-04-2007, 09:06 PM   #1
Default XXX-S Issue
Hey everyone, I'm obviously new here. I used the search button some for my problem but I didn't get anything useful.....
I got my first car for Christmas, a Team Losi XXX-S RTR. I know a good amount about how suspensions work, and I set up the front wheels to toe out about 2 degrees for good initial turn-in. However I just ran it to make sure nothing would fall apart with the wheels off the ground, and when I use the accelerator and turn the steering to lock on either side, I hear a fairly loud grinding sound from the wheel that would be inside the turn and the suspension vibrates. The CVD is at a pretty sharp angle at the spindle and carrier, but it's no more than 45 degrees. I'd like to keep the car set up with toe-out, but how do I get it to work without the grinding sound? I'm also running -1 degree of camber on the front.
Thanks for any help
Sweeney921 is offline   Reply With Quote
Old 01-04-2007, 09:21 PM   #2
Justinian's Avatar
I would check to see if the diffs are functioning smoothly, then look to see if there's some flashing or clearance issues between the axles and the hub / carrier assembles. On my XXX-S G+ I had to dremel a little material and hollow out part of the carreir so the CVDS didn't hit the carrier at full steering throw....
Other than that, not quite sure what's up there....
Justinian, Emperor and Roman God of Barrel-Rolls and Broken Parts...
________________________________________________
-Tamiya Evo V
-CRC T-Fource
-Losi XXX-S
-Darkside I-Force 10th scale pan car (under construction)
-Associated B4, T4
-Losi XXX-CR, XXX-4
"Evil will always triumph over good, because good is dumb!" :
-Dark Helmet, master of the Dark Side of the Shwartz......
Justinian is offline   Reply With Quote
Old 01-04-2007, 09:48 PM   #3
Jimmy Morris's Avatar
Turn the dual rate down on your radio. The wheels are turning too much and it's putting the cvd at too extreme of an angle and thats the chatter you are seeing/hearing.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 01-04-2007, 10:07 PM   #4
I)arkness's Avatar
i had the same pronlem with the uni's
the pin in the uni's are to long and is hitting the upright as it spins
to fix it, i pushed the pin more to one side then got a dremel and sanded down the pin to leave just the right amount so the uni's still works and in doing this it fixed the problem.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 01-05-2007, 05:10 AM   #5
I had the same exact problem with the xxx-s, and it seemed to be two problems actually for me...The first problem was that the CVDs were grinding like stated above (still have not fixed this even with dual rate very low) the second problem was that the tires rim was actually grinding away at the bottom of the shock towers on each side of the car... I helped to somewhat fix this problem by going to a smaller tire width, I believe it was 26mm...Hope this helps...
jeffbhhs is offline   Reply With Quote
Old 01-05-2007, 06:55 AM   #6
Won't the turning radius get a lot bigger if I turn the dual rate down? I don't know how big is big, but it's already about 5 feet.
Also, what upgrades should I look into the most? Graphite body parts, shocks, slicks, or something else?
Old 01-05-2007, 09:38 AM   #7
What do you plan on doing? Racing or just driving around the street?
Old 01-05-2007, 10:00 AM   #8
I'm just driving around getting better at driving for now but I'm gonna probably join the local racing league in the spring.
Old 01-05-2007, 07:30 PM   #9
I)arkness's Avatar
ive bought heaps of spares but havent used any yet, also with the carbon parts they have a more attendency to snap as there is not flex, but i would get a one-way and ball links for the steering up right as mine keep popping off once i hit somthing.
B.Portelli
Old 01-05-2007, 11:20 PM   #10
Still Bill's Avatar
My first car was a XXX-S RTR and this is exactly the problem it had at the front end.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-21-2007, 03:53 AM   #11
nemisis's Avatar
i would invest in a ally motor clamp as i had problems with the plastic one i found that as the motor was getting hot the motor mounting plate was getting hot and expanding the plastic causing the motor to shift and strip the spur gear
nemisis is offline   Reply With Quote
Old 01-21-2007, 08:00 AM   #12
HarshGuy's Avatar
Wow those were the days, that was 2 name changes ago ...wasn't it?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-21-2007, 08:16 AM   #13
POOKYT's Avatar
LMAO!!!!!! BUSTED!!!!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 01-21-2007, 09:17 AM   #14
Still Bill's Avatar
Brant
He's a total STALKER... Never expected HIM to find me here.
We don't call him HARSH for nothing!
Old 01-21-2007, 12:59 PM   #15
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to PoLsKiE
what size tires you using 28mm will rub on bottom of shock in front use 26mm and smaller and you'll be good
PoLsKiE is offline   Reply With Quote
HELP!!! ESC Issue Chris__RC Electric Off-Road 6 08-31-2008 01:31 PM
AE 18B Battery Issue Staufman Electric Off-Road 0 09-14-2007 06:19 PM
DPD issue Racingfreak6 Electric On-Road 5 01-01-2007 09:56 AM
OS .12 5p issue Black_Widow Nitro On-Road 4 12-18-2006 10:19 AM
Help with steering issue, please. LSUsportsfreak Electric Off-Road 10 06-17-2006 09:55 PM
