Old 07-08-2003, 09:33 AM   #1441
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by Randman
Dave - Just a thought, but could PAL make me orange caps as well?
OH man you have gone orange crazy j/k
Ko Racer is offline   Reply With Quote
Old 07-08-2003, 09:34 AM   #1442
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Ko Racer
yo bro.... you still using the yoko cap with the bleed screw?
I`m using the new blader type ones... not the ones with the screws and are plastic
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-08-2003, 09:35 AM   #1443
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Yes. Yes I have
Old 07-08-2003, 09:36 AM   #1444
Regional Moderator
-Dave
gotcha bro thanks!
Old 07-08-2003, 09:40 AM   #1445
How does the rebound differ between the bleed hole caps, and the bladder caps? I would think the bladders would have a much bouncier rebound.
Old 07-08-2003, 09:40 AM   #1446
sure can...
Old 07-08-2003, 09:45 AM   #1447
that can be adjusted by different firmness of foam inserts.... [email protected] ect
-Dave
Old 07-08-2003, 09:45 AM   #1448
God, I need to watch out, I'm dumping tons of cash into aftermarket parts on a car that's already LOADED. Just to show a little resistance against orange, I'll stick with the stock bleed caps, I've always liked them on my Yokomo cars...
Old 07-08-2003, 09:46 AM   #1449
-Dave
Without a foam insert, would it have similar rebound to the stock caps?
Old 07-08-2003, 11:20 AM   #1450
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
-Dave
Dave: with the bladder caps are you still using the long shocks in the rear ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-08-2003, 11:28 AM   #1451
kt racing's Avatar
Send a message via AIM to kt racing
dave,
I just want to know how that red bull tasted?
keith
kt racing is offline   Reply With Quote
Old 07-08-2003, 11:44 AM   #1452
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by kt tracing
dave,
keith
All good drivers know tha cafine filled softdrinks are the secret to good driving
Personaly I only like RedBull when it's mixed with another drink thats not so good for your driving skills good for a laugh though
I drink far too much coke though....
Herminator is offline   Reply With Quote
Old 07-08-2003, 12:09 PM   #1453
Pandora's Box's Avatar
Planning on getting on the Barracuda bandwagon . The Manual that comes with the kit is in Japanese.
I would appreciate it if anybody here could help me get an English version. There seems to be quite alot of notes in between each build. I want to build it right.
Do you guys really use the different length lower arms as a tuning option? or do you just leave it stock(long span) and tune it around it for small tight aggresive tracks?
Between the output gear and the diff gear....how much play do you allow?
And just one more......Do you leave any play in the diff which sits within the alloy bulkheads?
A Japanese girlfriend would sure come in handy right now!
Pandora's Box is offline   Reply With Quote
Old 07-08-2003, 12:29 PM   #1454
kt racing's Avatar
herminator,
I was actually talking about something else. We were at the nats and He didn't get any redbull all week long and him keep crying about it hahha. So I gave him one.
Old 07-08-2003, 12:33 PM   #1455
Herminator's Avatar
A big advantage of getting the kit from Speedtech is Steve's supplimentary sheets, detialing the tricky bits. The photo's are quite good for building the kit. JDM has done some work on translating the instructions, maybe he'll be able to help, when he's not polishing his 6 cars
I have stuck with the long suspension arms, I don't want a super agressive car, I can get a good setup fairly easily most of the time, infact if my setup is bad it's probably a problem with the car, namely when I had a little diff problem or a screw has loosened itself somewhere.
I leave as little play in the diffs between the bulkheads as I think is sensible without it being a tight fit, maybe enough for just one more shim to fit in but be snug against the bearing and diff. The diff gear mesh I've been experimenting with, the teeth are big enough to leave a large range possible for the mesh. I have it now so that there is about a millemeter of movement in the diff gear when I hold the smaller shaft gear still, a bit like meshing a spur and pinion.
If you've read this thread you'll see that getting the shaft aligned well is important, check alexracingusa.com for good building tips. The better the alignment and mesh of all parts in the drivetrain, the quieter it will be when you run it. Running without the diff cases also makes things quieter .
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
