Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 10-07-2006, 09:22 AM
  #14326
Unhappy Barracuds r3 parts
Hi
I live in the north west of england. I have just purchased an r3. D oes anyone have any parts. can you get parts from the the UK?
gio2174 is offline
Old 10-07-2006, 09:33 AM
  #14327
Talking Barracuda R3
Hi
Just bought an R3. What spare parts should i get, and what tends to break.
Race in doors on carpet.
Gary
gio2174 is offline
Old 10-07-2006, 08:01 PM
  #14328
Registered User
RC Infusion.com's Avatar
Hey Gary,
For spares, theres not much, everything on that car is pretty bullet proof. The only thing I found as a weak point was the steering rack, and front bumper brace. Other than that, you may want to keep a couple of steering knuckles and c-hubs on hand, never had a problem with the gears, but if you run outdoors, you might want to stock a spare bevel and input gear.
I ran a very tight indoor carpet and found I had to drill new holes for the tie rod ball mounts in the steering knuckles about 3mm closer to the c-hub, that added the extra steering I needed for the tight track.
If you don't find a UK parts reseller, I carry alot of spares here:
http://www.rcinfusion.com/CategoryLi...x?CategoryID=1
or hop ups here:
http://www.rcinfusion.com/ProductLis...?CategoryID=17
Enjoy, it's great kit.
Regards,
Rob
Originally Posted by gio2174
Hi
Gary
RC Infusion.com is offline
Old 10-09-2006, 06:14 AM
  #14329
Default Barracuda R3
Hi
I have a 10x1 and a 19t motor. What pinin and spur gear would be a good starting point for this setup?
Is the standard spur gear on this car a 64dp or a 48dp.
Gary
gio2174 is offline
Old 10-09-2006, 06:49 AM
  #14330
stjerno's Avatar
Talking
Hi
Gary
Hi Gary,
64 is standard ..
Gearing is a matter of track and motor. A 19t V2 dosen't take that many rpm's so I would gear it much higher that your 10t. (If its a V2 other 19t do a lot more rpm's)
I'm attaching the gear chart for you, if your track is medium try with 8:1 for your 10t and go from there. Stock spur is 90. I'v been running with everything from 6:1 to 10:1 depending on track and motor.
Best regards
Claus
www.a-rc.dk
File Type: pdf
stjerno is offline
Old 10-09-2006, 10:34 AM
  #14331
Registered User
Hi Gary,
Claus makes a good point, depends largely on track layout/conditions and motor. The stock internal transmission ratio is 2.4375, a general starting range for pinions with the 90T 64P stock spur is in the 25T to 30T range. Just keep an eye on the motor temp. You can download set up sheets here to keep track of things: http://www.rcinfusion.com/FreeThings.aspx
Rob
Hi
Gary
Old 10-16-2006, 08:15 AM
  #14332
TXR2Racer's Avatar
Does any know of a hobby store that still carries the 2 speed coversion for the R2 made by Alex Racing? Please let me know... I've seen pics of it before and would like to purchase one....
Thanks.....
TXR2Racer is offline
Old 06-15-2007, 03:16 PM
  #14333
Before I start, sorry to bring up such an old thread
I've just bought a barracuda r2, and have been told that the rear diff outdrives break really easy.
Now, what i would like to know is, is there a fix/solution to this problem? Can you use diff outdrives from another chassis, or can you do something to the standard ones to make them more reliable. Thanks in advance...
Drift Demon is offline
Old 06-15-2007, 03:50 PM
  #14334
COLEKO's Avatar
For my R3 I used the Yokomo aluminum diff sleeves..The part number is ZS-501R.
COLEKO is offline
Old 06-15-2007, 06:22 PM
  #14335
are R2 & R3 driveline/drivetrain parts similar if not the same?
Old 06-17-2007, 03:33 PM
  #14336
Default R3 Spares & Xenon bits 75% off
Just wanted to let everyone know, I have a large box of spares, all brand new still in the original Alex packaging. I also have many kit bags and some Xenon parts.
I have attached a stock list of what I have left. If you need anything, there is 75% discount, as long as you order 5 packs or more. Or make me an offer for the lot !
Contact : [email protected]
Its left over from when my I used to be the UK Distributor. Prices are in UK Pounds :-
Xenon Stock List.pdf
Alex Stock List.pdf
RWeatherley is offline
Old 11-10-2007, 01:11 PM
  #14337
u still have the barracuda parts?
potet is offline
Old 11-10-2007, 05:38 PM
  #14338
Ninja's Avatar
I have some parts laying here looking for a home. What are you looking for, and where do you live?
Ninja is offline
Old 10-27-2008, 03:48 AM
  #14339
chappi's Avatar
Trader Rating: 17 (95%+)
Got a 99% new R3 for sell , including 2 brand new un-build ball diff. intreseted PM me.
chappi is offline
Old 08-23-2010, 03:55 PM
  #14340
Default Foam Asfalt Beginner setup
Anybody still use this car?. I just bougt 3 1/2 of this cars to my GF Alex. She wanted to join me on the track and i got 3 1/2 of this cars with alot of spares and all the springs,nice hitec servo mamaba max 5700kv 4lipos etc for 120 bucks.. We had our first trackday 3days ago. At first i tried the car as it was. The 3 other car is just parts. This is a BarracudaR3 With all the alu parts minus the alu hubs. The car was all over the place and almost felt like a drifter. It has a one way front diff locked mid dif and standard in the rear. The track we drive the most is High grip,medium surface,open. I you wanna help me and need a better description of the track pm me and ill send you some pics. Please help me out with a easy to drive setup so my GF keeps the intrest P.S A Manual in English,spanish,Swedish.Danish or Norwegian Would really make me happy
VikNor is offline
