Alex Racing Barracuda R2 & R3
Originally Posted by dhiracing.com
Yep, quite some people still running them locally and in the National Championships too.
Current Championship Standings ...
- Beginners Stock Class - 2nd (R2 Xenon) & 6th (R3)
- Super Stock Class - 7th (R3) & 11th (R3)
//Kaare
gettting an r3 any setup help for carpet with foams
hey everyone,
could someone help me out and point me in the right direction of a base foam set-up for the R2. only problem is i have the kit springs only- or softer which isnt any use for foams... im primarily after suspension settings if you wouldnt mind. I have either a one-way or spool and race on outdoor asphalt.
also, if you wouldnt mind a decent rubber set-up??? kit springs should do okay i think, just dont know where to turn for a rubber set-up... also outdoor asphalt- fairly flowing course
i run stock
thanx
robbie
i run stock
thanx
robbie
anyone???
Originally Posted by xray racer
anyone???
http://www.rcinfusion.com/FreeThings.aspx
Regards,
Rob
yeh thanx- its somewhere to start from at least... so thank you! and the blank sheets are of great use.
by the way your site has some cool stuff on it
any other guru's around that know a set-up or two
cheers
robbie
cheers
robbie
anyone know what is the largest spur u can fit on a r3 and what comes with the kit thanks
The largest spur I have used on a R3 is 96T 64P
thank u
ANybody know where to get parts for the r2? besides speedtech, he's has everything except the drivetrain parts that i need.
Thanks, i love my cuda but cant run it right now
www.rcinfusion.com
Regards,
Rob
www.a-rc.dk has gear (and spring) charts online.
//Kaare
Thanks Rob, I just finished placing my order.
