Alex Racing Barracuda R2 & R3 >
Old 04-19-2005, 06:17 AM
  #14146
2mm...2.5mm....3mm...3.5mm...4mm...
Whatever you want. I dont know how thick it really has to be but I think 2.5mm should be enough. I am searching for more stiffness in the area of the stearing and the bulkheads...
Perhaps i will think about a new top deck as well... (TRF415, Xray T1FK05)
Chris
speedy-932 is offline
Old 04-19-2005, 06:22 AM
  #14147
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Chris
2.5~3mm would be great.. but the area around the front bumper mount and front sus ball mount holes needs to be a bit stonger.. and this showed on the 1st line of R2 chassis` and R3 chassis AKA the one good chrash and your chassis is on car
-Dave
JDM_DOHC_SiR is offline
Old 04-19-2005, 06:27 AM
  #14148
I know that... I have 2 damaged chassis plates here... but Im not sure how to improve the durability of the front end... tell me and i will do it.
BTW... I made a new damper stay which is wider... now I can use the outest hole on the damper stay, too...
Chris
Old 04-19-2005, 11:46 AM
  #14149
MikeR's Avatar
Trader Rating: 15 (100%+)
I have alot of spare parts and hop ups for sale here for R2/R3 users! PM me if interested.
http://www.rctech.net/forum/showthre...54#post1528154
MikeR is offline
Old 04-20-2005, 02:13 AM
  #14150
No more ALEX Car for you Mike?? ....
Old 04-20-2005, 07:33 AM
  #14151
seaball's Avatar
alex springs
hey fellas,
a brief question. do any of you know what the spring range is for the all the alex (black )springs? not necessarily every spring, but an idea of how stiff the stiffest is? 1.5mmx5.0 turns? lb/in or g/mm... i can work from there.
greatly appreciated.
- chris
seaball is offline
Old 04-20-2005, 07:36 AM
  #14152
stjerno's Avatar
Default Re: alex springs
Originally posted by seaball
hey fellas,
- chris
I posted a spring chart a page or 2 back ..
Stjerno
stjerno is offline
Old 04-20-2005, 08:53 AM
  #14153
MikeR's Avatar
No sorry, not on the team anymore
I just wanted to try something new. It's been an excellent car for me the past 2 years though.
Cheers!
MikeR is offline
Old 04-20-2005, 09:01 AM
  #14154
seaball's Avatar
Thumbs up thanks
i haven't looked at this thread in months. my fault. i get so irritated anymore with people not using the search function of this board before posting.... and here i am asking away w/o even checking the recent posts....
i did think to check, but i thought, "what are the chances this was just covered?".... i'll risk it.
thanks again. i can't believe these top out at 25lbs!
seaball is offline
Old 04-21-2005, 09:54 PM
  #14155
Thumbs up ALEX Racings New Car
They have a name for it now
STINGER ..
more to come in the next couple of weeks
-Dave
Old 04-22-2005, 01:37 AM
  #14156
Thumbs up more info
Looks like the car will be Shaft Driven at 1st ... but very different from the Barracuda the batteries "SHOULD" be on the Right hand side like the Cuda..... . but the suspension geo' is very different ... and it will have open bulkheads for easy access....... But look for a conversion on the car after it comes out ..??? Belt conversion...so you can run the same car but choose your type of drive system ... look to be interesting.... if they can pull it off... and be able to finish the prototype before the middle of May before the Shizoka Hobby Show
-Dave
Old 04-22-2005, 01:55 AM
  #14157
utieh's Avatar
Default Re: more info
-Dave
Thanks a lot for the info!
Did Alex thought about hiring some factory drivers since Xenon is now using Tamiya cars?
utieh is offline
Old 04-22-2005, 02:08 AM
  #14158
Default Re: Re: more info
ALEX Has only 2 drivers that I know of Right now.... thats it
Nakabayashi...(use to race for ATLAS)
Shimiya....(PAL)
Old 04-22-2005, 05:24 AM
  #14159
gene465's Avatar
Trader Rating: 25 (100%+)
Default Re: ALEX Racings New Car
STINGER ..
-Dave
Looks promising! Thanks Dave!
gene465 is offline
Old 04-22-2005, 07:06 PM
  #14160
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
That sounds pretty cool. Might be into another Alex car down the road. Starting to fly electric heli's at this time and having a blast. If I get another touring car it is to run asphalt only with rubber tires. I'm done running carpet and tired of foams.
wyd is offline
