Alex Racing Barracuda R2 & R3 >
Old 04-17-2005, 12:40 PM
  #14116
berger's Avatar
You have the low profile composite block thing which fits under the side with the shaft, and either an alloy transponder mount or anouther block for the other side. It should all fit in okay...!
berger is offline
Old 04-17-2005, 01:14 PM
  #14117
Suspended
i need to replace the shaft on my R2
will a shaft from a TC3 or Yokomo fit? I can't seem to find an R2 shaft instock anywhere.
403forbidden is offline
Old 04-17-2005, 01:18 PM
  #14118
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Which style shaft do you need?? I have a couple of spare stock R2 shafts... they have the spur mount attached to the shaft...
R
AZ_Ron is offline
Old 04-17-2005, 01:21 PM
  #14119
Suspended
i have the Xenon stage 2 upgrade...is that a different Shaft from stock?
Old 04-17-2005, 04:37 PM
  #14120
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
You can make a R3 shaft work
-Dave
JDM_DOHC_SiR is offline
Old 04-17-2005, 09:06 PM
  #14121
gene465's Avatar
Trader Rating: 25 (100%+)
Do the R2 steering knuckles fit the R3? Any are there any other steering knuckles that will fit. I ran the car for my first heat today and it was dialed except my motor loosened up messing up the pinion/spur mesh. Loved the way it ran on the track but just need to get some front knuckles and a few med span front A-arms before I can go all out and not be so cautious! Thanks Gene
gene465 is offline
Old 04-17-2005, 09:15 PM
  #14122
AZ_Ron's Avatar
Hey Gene... Glad you like the car...
I did some comparisons in the LHS a few weeks ago...it looked like one of the HPI front knuckles were very close, and may have worked, but I didn't buy them to open up the package and find out...
R
AZ_Ron is offline
Old 04-17-2005, 09:27 PM
  #14123
Suspended
still got those shafts? i need one or two
Old 04-17-2005, 09:31 PM
  #14124
AZ_Ron's Avatar
403... Do you have a pic of the shaft you have?
If it's the same as what I've got, I've got a red one, and a blue one... I think...let me know... I'll see what I've got...
AZ_Ron is offline
Old 04-17-2005, 09:45 PM
  #14125
Suspended
ok cool i will take some pics
Old 04-17-2005, 09:54 PM
  #14126
Suspended
ok here is the pics of my shaft car
Old 04-17-2005, 10:05 PM
  #14127
AZ_Ron's Avatar
is your shaft like a tc3's?, round with drive pins on both ends?
AZ_Ron is offline
Old 04-17-2005, 10:26 PM
  #14128
Suspended
yeah...like a really long dogbone
Old 04-17-2005, 10:33 PM
  #14129
AZ_Ron's Avatar
Bummer... you have the 'conversion' shaft I believe...
The two I have are both graphite with the aluminum ends molded/fused on... with one end have the aluminum adapter for the spur gear...
R
AZ_Ron is offline
Old 04-17-2005, 10:34 PM
  #14130
Suspended
R
ahh i see...thanks for the help anyhow
